Author Topic: Machining in oil squiters  (Read 2558 times)
August 17, 2010, 01:56:37 pm
monomer
  • 414
« on: August 17, 2010, 01:56:37 pm »
I've just got back my job as a machinist, working on automotive production machines. One of the perks of the job is I get to abuse the lathe/mill after work.
Whats the process to drill the squirters into the oil galley?
I assume it something like:
-Mill the surface flat
-Tilt head the right amount of degrees to hit the galley
-Drill, drill smaller then the od of the squirter (I have stock OEM VW ones here)
-Mill/bore/ream out the final hold (perpendicular) to seat the squirter in.
Sound about right? Never done any block work before.
www.michiganvw.org
Reply #1August 17, 2010, 05:21:09 pm
clarkrep
  • 117
Re: Machining in oil squiters
« Reply #1 on: August 17, 2010, 05:21:09 pm »
Sounds about right.
I plan to do this to a hydro na block I've got. The only thing I'm unsure of is the length of tooling specifically milling the bore. You might be able to center drill, drill and ream instead of milling the pocket.
I'm not sure how soon I'll get to this though. Let us know how well it works.
Aaron
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #2August 17, 2010, 06:03:53 pm
toywagen
  • 22
« Reply #2 on: August 17, 2010, 06:03:53 pm »
BMW has banjo-style squirters that only need one hole. They were $11 each at Brian Jessel in Vancouver. They also have a nice valve inside the bolt that closes at low pressure. It was easy and I did it by hand. If I had a mill though...
Reply #3August 17, 2010, 10:56:33 pm
monomer
  • 414
« Reply #3 on: August 17, 2010, 10:56:33 pm »
The squirters go in the block not the head.
Did it sound like they didn't?
I don't recall seeing the surface milled, I'll have to take a look.
www.michiganvw.org
Reply #4August 17, 2010, 11:38:25 pm
Quantum TD
  • 1195
« Reply #4 on: August 17, 2010, 11:38:25 pm »
I want to think that only the Hydro blocks had the milled surface, or perhaps it's as Andrew noted: only 12mm blocks. I guess you'll let us know when you pull the pan.
Reply #5August 18, 2010, 04:35:43 am
monomer
  • 414
« Reply #5 on: August 18, 2010, 04:35:43 am »
I guess you were talking about the head of the mill, but that didn't make sense to me either as the hole is drilled perpendicular to the milled surface and just before you mentioned milling the surface flat.
You have to drill a few degrees to hit the galley, correct?
Pan's off, bare machined block has been sitting for nearly a year now waiting to get finished.
www.michiganvw.org
