Author Topic: Crazy idea? 1992 3 speed automatic transmission with 1.6 diesel engine?  (Read 4994 times)
August 17, 2010, 05:38:10 am
srgtlord
  • 797
Was just wondering if this would work at all and if I would need any special parts to complete the swap. FYI this would be going into a rust free 1992 vw cabriolet.
Reply #1August 17, 2010, 08:02:41 am
honda_is_the_best
  • 104
Re: Crazy idea? 1992 3 speed automatic transmission with 1.6 diesel engine?
« Reply #1 on: August 17, 2010, 08:02:41 am »
need one key piece.. an ever so illusive auto diesel starter.. made from unobtanium..
and all the mounts/brackets/cables/shifters that pertain to the installation. ive thought about this swap before, it would be fun in a car with a turbo, and some power, because you could spool the turbo against the transmission.
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Reply #2August 18, 2010, 07:24:37 pm
« Reply #2 on: August 18, 2010, 07:24:37 pm »
a 3spd auto trans is spinning 3100 at 65mph.. Bad Bad diesel ratios.
"096" 4 Speed Automatic code CFF from a VR6 Corrado, Golf/Jetta III, Passat. It will spin 2400 at 65mph, dunno if it would ever work.. but a 4spd auto would be way better Idea..
Reply #3August 18, 2010, 07:27:33 pm
maxfax
  • 2126
« Reply #3 on: August 18, 2010, 07:27:33 pm »
The 4 speed is electronic but uses a stand alone controler IIRC..  Not sure what inputs it would need..  TIme to have a look at alldata......
