Author Topic: Bosio PP520 vs. OEM ?  (Read 4830 times)
August 15, 2010, 09:00:41 am
ventureforth
  • 164
« on: August 15, 2010, 09:00:41 am »
Is there a difference between the larger OEM nozzles that make some ALH (i.e. Passat) applications 110HP vs. Bosio PP520 nozzles which appear to provide the same power upgrade?
Thanks.
Reply #1August 15, 2010, 09:02:43 am
Re: Bosio PP520 vs. OEM ?
« Reply #1 on: August 15, 2010, 09:02:43 am »
if you want i have a dss nozzle
Reply #2August 15, 2010, 09:09:54 am
ventureforth
  • 164
« Reply #2 on: August 15, 2010, 09:09:54 am »
I should note that I have a set of PP520 nozzles, but am wondering if it's worth installing them or if I should sell them instead?
Reply #3August 31, 2010, 01:52:25 pm
sprstu
  • 99
« Reply #3 on: August 31, 2010, 01:52:25 pm »
The stock oem upgrade is more similar to the Sprint520 which are smaller than the PP520. I ran the pp520 on a stock turbo and stock chip and it was a blast. My roommate has the stock chip/turbo with the Sprint520 and I was much faster all over the rev range. Then I added a chip and the power increase is phenomenal.
Mk1 caddy TD, mk4 Golf Tdi
