S-PAutomotive.com
Author Topic: So I FINALLY did it  (Read 3506 times)
August 08, 2010, 08:57:17 pm
BellCityDubber
  • 251
So I FINALLY did it
« on: August 08, 2010, 08:57:17 pm »
so after a year of having the TD's pump and injectors done, I FINALLY managed to get it down the track
and it ran a 17.5s pass.... probably 16s in the right hands.
here's the slip
R/T....534
60'......2.712
330.....7.568
1/8th...11.416
MPH.....66.13
1000.....14.743
1/4.......17.532
MPH......82.47
This was a cold night (awesome) with a greasy cold track surface (not awesome) so it was hard as hell to hook up (I spun first.. TWICE, AND second - there's that torque) and I still dont know how to launch the clutch properly...
The car weighs somewhere up in the 2500 with the stereo, some tools, and the spare in the trunk.. so we'll say 2550
so by the calculators I've got 110 hp to the flywheel.
I would imagine more if I got a "perfect" run out of it.
Still, I'm at now, where my GTI WAS before I put the head and headders on it.
Lower times comming.... watch this space.
Reply #1August 27, 2010, 05:54:53 pm
clarkrep
  • 117
Re: So I FINALLY did it
« Reply #1 on: August 27, 2010, 05:54:53 pm »
Nice numbers! I'm kinda curious what a factory td would do...
What chassis do you have anyway? Mk2?
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #2September 24, 2010, 02:00:32 pm
BellCityDubber
  • 251
« Reply #2 on: September 24, 2010, 02:00:32 pm »
Yes, mk2...
and it's not exactly stock
that's a giles superpump, matched injectors by giles, and a large FMIC setup running 25 psi with a 4 puck unsprung clutch hub and upgraded pressure plate
so no.... not stock
Reply #3November 02, 2010, 03:08:52 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #3 on: November 02, 2010, 03:08:52 am »
what turbo?
'91 Golf Cabrio 1.9TD
Reply #4December 22, 2010, 03:19:56 pm
BellCityDubber
  • 251
« Reply #4 on: December 22, 2010, 03:19:56 pm »
Stock K24
stock downpipe :(
 (hope to change that this year or next - I've also been looking into a 1.9td headswap....)
Reply #5January 29, 2011, 09:35:59 am
  • 5064
« Reply #5 on: January 29, 2011, 09:35:59 am »
i did 16.2 with a gtech, 2.25 exhaust, cone filter, 25-30psi, and black smoke in a mk1 jetta coupe.
S-PAutomotive.com
