Fixmyvw.com
Author Topic: how do i get these pistons out?  (Read 4468 times)
August 05, 2010, 08:24:14 pm
goon
  • 35
« on: August 05, 2010, 08:24:14 pm »
alright i bought a "good running motor" from a guy in new york said it had a fresh rebuild to it and made me look like a fool..
when i put it in and tried to crank it over... i got nothing.. like the starter said hell no.. so i tried to hand crank it and there was no way i was going to be able to move it so last resort (didnt care much at this point) i put it in 4th gear and rocked it till it actually moved...
well turn out it was only because the clutch slipped...
this is what  i saw when i took the head off...
( added pb to try to free it up when i get the head off thats what all the liquid is)
seized motor
cyl No1
cyl No2
cyl No3
cyl No4
cleared out the fluid so you can see
cyl No1
cyl No2
cyl No3
cyl No4
NOTE THE CIRCULAR MARKS ARE FROM ME!! NOT VALVES i tried taking a hammer to see if i could loosen things up
my question now is how the hell do i free this up? im going to do a fresh hone and rings and bore if it needs it( the walls dont look to bad besides the rust)
but how can i get these pistons out i know they only come out the top so.. do i just pound the *** out of them till they pop out from the bottoms side? i dont want to ruin the pistons..
HELP!!!
Reply #1August 05, 2010, 09:01:04 pm
rallydiesel
  • 1880
Re: how do i get these pistons out?
« Reply #1 on: August 05, 2010, 09:01:04 pm »
I would just spray wd40 or whatever your choice penetrating oil is from top and bottom. Then pound the pistons out from top or bottom using a brass or hardwood dowel and hammer. I assume the motor is not turbo or else you will need to remove the oil squirters.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2August 05, 2010, 11:08:06 pm
mmitocky
  • 23
« Reply #2 on: August 05, 2010, 11:08:06 pm »
You can try letting Coca-Cola sit in the bores that are frozen solid....I have heard from two people who tried using all sorts of penetrating oils that the Coke was the only thing that freed up the pistons (rings most likely) in the bores.
Reply #3August 05, 2010, 11:30:18 pm
goon
  • 35
« Reply #3 on: August 05, 2010, 11:30:18 pm »
coca cola?!... ok ill give it a shot im willing to try anything at this point
Reply #4August 05, 2010, 11:34:05 pm
  • 7834
« Reply #4 on: August 05, 2010, 11:34:05 pm »
Get yourself a 2x4 and a BFH and go to town. You might break a piston but that isn't as bad as what mine looked like and they came out fine. My machinist even said no bore needed :D.
That was after I hammered them loose :D
« Last Edit: August 05, 2010, 11:35:41 pm by theman53 »
Reply #5August 06, 2010, 06:59:04 am
rs899
  • 647
« Reply #5 on: August 06, 2010, 06:59:04 am »
The "active ingredient" in Coke is phosphoric acid.  Rather than have all that nasty corn sweetener to deal with go over to Home Depot and get a gallon of phosphoric acid either in the paint department or near the concrete ( also used for etching concrete).  I have never used it on alloys though so better watch what it does to the pistons carefully.  I am not a machinist, but I wouldn't be comfortable running that engine without a rebore.  I don't think new rings will last very long with that kind of pitting- but I might be wrong...
Reply #6August 06, 2010, 08:12:40 am
  • 7834
« Reply #6 on: August 06, 2010, 08:12:40 am »
this guy
on the end of this with the other end on your pistons
If I remember I had to cut my 2x4 down to 2x3 or so. My engine went from looking like that pic I have above to this
It was bored, cleaned, painted, and machined...the 2x4 didn't do miracles :D
« Last Edit: August 06, 2010, 05:53:18 pm by theman53 »
Reply #7August 06, 2010, 08:25:37 am
pyro7890
  • 47
« Reply #7 on: August 06, 2010, 08:25:37 am »
my father has an old tractor a 1928 john deere d and we put a half and half acetone and atf transmission fluid sit in it. it is by far the best penatrating oil you can make and its also the cheapest. also you have to stir it every once and a while because they tend to separate and cover the holes also. do some reasearch on it. then i would take it to a big hydraulic press after you let it soak for a week or so and they should come.
there was an article comparing various penetrates in the April 2007 issue of Machinist Morkshop Magazine. They arranged a subjective test of all of the popular penetrants with the control being the torque required to remove the nut from a scientifically rusted environment.
Penetrant: Average Load:
none 516 ft lbs
WD40 238
PB Blaster 214
Liquid Wrench 127
Kano Kroil 106
ATF-Acetone mix 53
hope i was some help
Reply #8August 06, 2010, 10:02:44 am
« Reply #8 on: August 06, 2010, 10:02:44 am »
When you are hammering away on the pistons keep in mind that they have to come out the top
Reply #9August 06, 2010, 02:10:45 pm
BAM
« Reply #9 on: August 06, 2010, 02:10:45 pm »
Here's my two cents.  You have a diesel car with 55L tank, use a half cup of fuel or to taste down each cylinder.  Let set couple days or if you can't wait try turn crank after couple hours at least.  I have seen worst free up and get a re-ring, over 200000km later all good. :) :)
Reply #10August 06, 2010, 04:47:38 pm
« Reply #10 on: August 06, 2010, 04:47:38 pm »
[/b]
it works!
Reply #11August 06, 2010, 04:50:19 pm
« Reply #11 on: August 06, 2010, 04:50:19 pm »
another thing, if you beat the pistons up too much, your gonna need new ones..
Reply #12August 06, 2010, 06:34:45 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #12 on: August 06, 2010, 06:34:45 pm »
Why did they lock up?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #13August 07, 2010, 04:33:52 pm
« Reply #13 on: August 07, 2010, 04:33:52 pm »
It looks to me like water got in there.
Reply #14August 07, 2010, 04:45:31 pm
madmedix
  • 204
« Reply #14 on: August 07, 2010, 04:45:31 pm »
The absolutely best penetrant I have ever used (worked where everything else did not, including impact socket and a 6 ft iron pipe for leverage on the hub nuts) is half brake fluid and half auto tranny fluid. I put it in a squeezable mustard bottle with some hose attached. Absolutely miracle stuff.
ANdy
'90 TD Jetta
S-PAutomotive.com
