Author Topic: dial indicator-why  (Read 2044 times)
August 04, 2010, 06:31:45 am
mtrans
  • 308
dial indicator-why
« on: August 04, 2010, 06:31:45 am »
Lastly I purchase,but when I Turn engine counterclockwise until dial stops (get 0.95mm) Zero gauge Turn
engine slowly back to TDC I get 1.12mm.Why is that difference, Is that only me,and 1.12 is important namber we look for right?of corse 1.12 is too advanced.Best
I`ll improve my English
Reply #1August 04, 2010, 08:19:54 am
Re: dial indicator-why
« Reply #1 on: August 04, 2010, 08:19:54 am »
It's the slack in the belt. What you are demonstrating is the importance of going back at least 1 compression stroke before going clockwise to take a reading or to check your timing marks. Or just always go clockwise and you won't need to worry about that.
Reply #2August 04, 2010, 09:27:40 am
Baron VonZeppelin
« Reply #2 on: August 04, 2010, 09:27:40 am »
Sometimes too, you need to push the dial stem downward once you've stopped rotating engine to make sure it has full contact.
I do that to the dial stem at every checkpoint.
Reply #3August 05, 2010, 12:10:01 pm
mtrans
  • 308
« Reply #3 on: August 05, 2010, 12:10:01 pm »
thanks guys
