Author Topic: gearbox noisy at idle until clutch pressed in  (Read 7192 times)
Reply #15August 06, 2010, 04:35:03 pm
Re: gearbox noisy at idle until clutch pressed in
« Reply #15 on: August 06, 2010, 04:35:03 pm »
http://www.brokevw.com/
Everything you did or didn't want to know about the VW 020 trans
Reply #16August 07, 2010, 11:11:08 am
« Reply #16 on: August 07, 2010, 11:11:08 am »
Are these easy to get at?
what? easy to get at what?
Reply #17August 07, 2010, 01:28:14 pm
LoneWolf
« Reply #17 on: August 07, 2010, 01:28:14 pm »
at the bearings you suggested
Reply #18August 07, 2010, 04:26:44 pm
« Reply #18 on: August 07, 2010, 04:26:44 pm »
you have to tear the trans apart into a million pieces afaik..
Reply #19August 08, 2010, 03:23:34 am
rs899
  • 647
« Reply #19 on: August 08, 2010, 03:23:34 am »
Either way, there's no magic bullet for this.  Pull it, look for clutch/prssure plate issues.  If nothing jumps out at you there, buy another gearbox.   You might be able to figure it out using a stethoscope applied to both areas of the gearbox.  A rattle would suggest clutch, a rumble would suggest gearbox.
