Author Topic: Leaking oil cooler  (Read 4865 times)
December 17, 2005, 11:13:44 am
Red Rabbit
  • 84
Leaking oil cooler
« on: December 17, 2005, 11:13:44 am »
1984 1.6 TD, oil cooler is leaking. Could I just remove it and drive without it (re-routing oil and coolant lines, of course)? I'm a pretty conservative driver,  and use a quality synthetic oil. Or am I asking for trouble?.....
No I am NOT in denial!!!!!
Reply #1December 17, 2005, 11:27:24 am
vwmike
  • 1158
Leaking oil cooler
« Reply #1 on: December 17, 2005, 11:27:24 am »
You could probably get away with it where you live and with the temps how they are right now, but there would still be a drawback. The stock oil cooler also warms the oil during the warm-up cycle so it would take longer for your engine to warm up. That might not be a good thing. Chances are though, if your car has an oil cooler from the factory then it actually needs a bigger one so removing it completely wouldn't be adviseable.
Reply #2December 17, 2005, 11:37:32 am
Red Rabbit
  • 84
Leaking oil cooler
« Reply #2 on: December 17, 2005, 11:37:32 am »
Thanks for the reply. It still has the original oil  cooler unit, but I'm unsure what you mean by " it actually needs a bigger one".  Do you mean an after market unit with a larger capacity?... seems as if this oil cooler has lasted 21 years without the turbo/engine blowing up, it must be adequate for this engine.
Reply #3December 17, 2005, 01:01:59 pm
vwmike
  • 1158
Leaking oil cooler
« Reply #3 on: December 17, 2005, 01:01:59 pm »
It may work well enough but ideally most of the stock oil coolers leave much to be desired. That's all I'm saying. There are actually larger factory ones out there that can be swapped on to improve efficiency.
Reply #4December 17, 2005, 01:46:26 pm
Red Rabbit
  • 84
Leaking oil cooler
« Reply #4 on: December 17, 2005, 01:46:26 pm »
I have seen one  type of after market oil cooler which has a 'mini radiator' style of set-up, problem is  my car has A/C (yes, it works :D ), and there is not much room to mount it up front.  I might just  buy a new unit and replace like for like.
Reply #5December 25, 2005, 10:31:37 pm
myke_w
  • 1099
Leaking oil cooler
« Reply #5 on: December 25, 2005, 10:31:37 pm »
all the hassle that it would require to upgrade or negate the original cooler would take you longer and cost more than just redoing all the gaskets on it. The one that mates to the block is 65 cents, the o-ring one is under 5 bucks.
Also be sure it's not the furrlue nut that holds the oil line down that isn't leaking, that can be a source of problems for TD's.
Reply #6January 14, 2006, 06:23:57 pm
52 horses
RE: Leaking oil cooler
« Reply #6 on: January 14, 2006, 06:23:57 pm »
All I can say is watch that it does not explode on you... I had that happen on my '84 GLI... Talk about a mess.. Although I didn't have to worry about undercoating.... :lol:.. When it blew it took out all my coolant and oil.. Gotta love Amsoil for saving my engine.. cuz I thought that it was just the oil pressure gage that failed until the buzzer sounded about another couple of klms down the road...
