Author Topic: Clunk front drivers side  (Read 3470 times)
August 02, 2010, 12:28:28 pm
shawnm
  • 3
« on: August 02, 2010, 12:28:28 pm »
I've been chasing a noise in the front end of my 1995 Jetta. I replaced the rear control arm bushing, the front one is still tight, I put in a new strut mount bearing and replaced the broken coil spring.
Still I have the constant clunk\rattle while driving down relatively smooth roads. I know my brake pads are rattling some but I am chasing a different noise. I can almost feel the clunk in the floor.
What else could cause the noise?
Reply #1August 05, 2010, 10:20:11 am
  • 3468
    • McScrubbins Body Wash
Re: Clunk front drivers side
« Reply #1 on: August 05, 2010, 10:20:11 am »
exhaust hitting that alluminium heat shield
Reply #2August 05, 2010, 04:30:58 pm
  • 1739
« Reply #2 on: August 05, 2010, 04:30:58 pm »
sway bar bushings. they are right below your foot. also the rear bushing at the front table.
Reply #3August 06, 2010, 05:39:42 am
shawnm
  • 3
« Reply #3 on: August 06, 2010, 05:39:42 am »
Turns out I had a strut die after only being 4 months old. Monroe sensa tracs had a lifetime warranty so I lucked out there.
caveman - I was convinced the sway bar was the issue so I went as far as removing it completely without any change.
