Author Topic: Klaus, the 84 Jetta TD, gets a rebuild  (Read 67950 times)
Reply #75November 14, 2010, 09:22:59 am
arnold
Re: Klaus, the 84 Jetta TD, gets a rebuild
« Reply #75 on: November 14, 2010, 09:22:59 am »
How exactly did you set the timing on the engine stand without flywheel and trans installed ?
Reply #76November 14, 2010, 01:30:33 pm
« Reply #76 on: November 14, 2010, 01:30:33 pm »
I had marked a spot on the timing sprocket against the block. Going to reset the timing now to 0.9mm anyway though.
Reply #77November 27, 2010, 04:24:04 pm
« Reply #77 on: November 27, 2010, 04:24:04 pm »
More progress!
Got a new steering column bearing and got my dad to press it in. Steering column all tightened up and reinstalled!
Also he came up with a good fix for the air box which had worn down the latch area:
Spent some time today fixing up wiring that was broken or about to break. Replaced the fan plug with new style to match the new fan.
Then got the turbo back on (had to get it sent out to get the broken stud out), got the downpipe on, and reset timing to 0.9mm.
Replaced passenger side axle with reman unit.
With the help of everybody up at the shop this weekend, got the engine back in! Resting on the side and front mount. Still need to get the rear mount on. Obviously still need to hook everything up!
More coming tomorrow!
Reply #78November 27, 2010, 05:46:39 pm
arsenicpants
« Reply #78 on: November 27, 2010, 05:46:39 pm »
your injectors should not be connected to your LDA :P
otherwise motor looks great!
Reply #79November 27, 2010, 07:16:54 pm
Thezorn
  • 381
« Reply #79 on: November 27, 2010, 07:16:54 pm »
Yeah, that won't work well that way.
In case your not sure, the injector overflow line that you have connected to the LDA should go to a barbed fitting on the back side of the injection pump.
The LDA line should be connected to your intake manifold (there should be another barbed fitting on the inlet elbow of the intake). It needs to be here because the LDA is controlled by "boost pressure" which adjust fueling accordingly.
-Will
Compounded 93 AAZ
Reply #80November 27, 2010, 08:17:47 pm
« Reply #80 on: November 27, 2010, 08:17:47 pm »
Just checking to make sure people were actually looking at my pretty pictures  ;)
Reply #81November 28, 2010, 10:04:48 am
« Reply #81 on: November 28, 2010, 10:04:48 am »
this is like diesel porn.. of course were looking!
great work BTW.. you are gonna have a BRAND NEW mk1 TD Jetta in the end..
Reply #82November 28, 2010, 07:17:23 pm
« Reply #82 on: November 28, 2010, 07:17:23 pm »
Got more done today. So close to being able to start!
Got the car up on the lift and connected the driveshafts, downpipe to exhaust (curse you toilet bowl clips!), front and rear motor mounts, and shift linkage.
Got a lot of the hoses connected, fuel lines connected, radiator and fan back in. Reconnected about 80% of the engine bay stuff. Need to do some more research on the wiring. Got stuck on a few connectors which I didn't label and can't remember where they go. I'll probably start another thread on matching those up.
Got stuck on the ignition switch housing on the steering column. Can't get it on far enough to get the bolt in that holds it to the outer column sleeve, seems stuck.. Also need to install the EGT gauge.
I'd say we are about one good day's worth of work away from a start attempt!
Reply #83November 28, 2010, 07:20:11 pm
mtnbob
  • 738
« Reply #83 on: November 28, 2010, 07:20:11 pm »
Beautiful work. I am taking notes and will reference some of your pictures as I try to get mine back together!!
96 Subaru Outback Wagon
Reply #84November 28, 2010, 07:42:27 pm
JessaBug
  • 112
« Reply #84 on: November 28, 2010, 07:42:27 pm »
Glad we can be of assistance! Its certainly been one heck of a fun project. I know I've learned a ton (its so much easier to learn how an engine works when its apart!). Not to mention, I've learned just how much I like wrenching on cars :)
Can't wait to get the car started again. We're so close! Hopefully just another day of working on it will lead to a starting attempt...
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #85November 28, 2010, 07:46:24 pm
« Reply #85 on: November 28, 2010, 07:46:24 pm »
I've posted a separate thread in the troubleshooting section for my wiring identification issues. Please take a look!
http://www.vwdiesel.net/forum/index.php?topic=27687.0
Reply #86December 05, 2010, 06:30:45 pm
« Reply #86 on: December 05, 2010, 06:30:45 pm »
Well after a few mis-steps, the engine is running!
Had to clean the grounding points of paint and run an additional ground cable to one of the starter bolts before it cranked.
Making good oil pressure. Drove it only about 3 miles total this weekend. Looks like the fan switch crapped out, and is leaking around the seal to boot. Tested the new fan by jumping the wiring at the switch and it works, so a new one is on order. In the short driving, only saw EGTs to about 5-600 *F.
Shift linkage is not quite right. Looks like the main shift selector rod got bent at the paint shop. Luckily found a replacement locally along with a full bushing kit and the other transfer rods.
Hopefully next weekend will rectify the shifting issues and radiator fan. Need to clean up some wiring and mount the EGT gauge more permanently. A few other misc. small things. Also need to get the coilovers installed and the rear bumper tucked.
But overall, running quite well! Very quick and easy starting, and sounding good!
Reply #87December 05, 2010, 08:42:52 pm
xxkoadyxx
  • 179
« Reply #87 on: December 05, 2010, 08:42:52 pm »
This is very sweet! im hoping to rebuild my spare 1.9td for my mk3 while its chillin in the garage.
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #88December 06, 2010, 08:13:40 am
GEE-BEE
  • 1604
« Reply #88 on: December 06, 2010, 08:13:40 am »
If you want to fill in the gap between the radiator and core support let me know I will mail you the correct seal for that ?
Did you go to the MKII 250 watt scirocco fan  ( two speed) ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #89December 06, 2010, 08:41:41 am
madmedix
  • 204
« Reply #89 on: December 06, 2010, 08:41:41 am »
Oh, I've got a soft spot for those Jettas. Beautiful job. I also have a soft spot for a lift and garage like you've got  ;D
Good work.
Andy
'90 TD Jetta
