General Information
Troubleshooting
Suspension MK2
Topic: Suspension MK2 (Read 3888 times)
July 29, 2010, 02:45:59 pm
Suspension MK2
July 29, 2010, 02:45:59 pm »
I replaced my struts, springs and all the rubber bushings so my suspension is "new" more or less. Just with short springs. I'm using nitrogen struts as well.
My rear struts protrude through the back shelf... im just wondering how i fix that? why is it so high?
also, my front driverside strut sounds loose somehow. It rattles like crazy over bumps. The top of the strut looks higher on the driver side than the passenger side.
Anyone have any advice for me?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
July 29, 2010, 04:14:11 pm
Re: Suspension MK2
July 29, 2010, 04:14:11 pm »
Something was missed when the struts were replaced. Most probably the special washer with the groove that goes on the circlip just below the threaded part of the shock.
July 29, 2010, 04:33:00 pm
Re: Suspension MK2
July 29, 2010, 04:33:00 pm »
for the front check the ball joints. Mine clunked a lot when they were bad
July 30, 2010, 12:29:29 am
Re: Suspension MK2
July 30, 2010, 12:29:29 am »
Quote from: burn_your_money on July 29, 2010, 04:33:00 pm
check that the strut bearings are tight. my cars rattle going over bumps when the bearings get loose, or were never tightened to begin with.
July 31, 2010, 01:08:34 pm
Re: Suspension MK2
July 31, 2010, 01:08:34 pm »
I got new washer things. I remember buying them. ill have to take them apart i guess.
THROWN ROD
General Information
Troubleshooting
Suspension MK2
