Author Topic: Torque spec - flywheel bolts  (Read 14037 times)
July 09, 2004, 01:50:13 pm
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« on: July 09, 2004, 01:50:13 pm »
I am trying to sufficiently tighten the 9mm 12-point bolts that hold the flywheel to the pressure plate.
If I read my Bentley right (page 38) I am supposed to use thread-locker and tighen them to 74 lb-ft. Is this correct?
The reason I ask is I just snapped one off while trying to tighten it...and I had only gotten to about 70 lb-ft.
Thanks for the help...by the way, the replacement crank is in...and I am cruising on putting the parts back on to get this thing running...hopefully in the next couple of days depending on free time (what is that?)
Mikey
Reply #1July 09, 2004, 05:55:31 pm
fspGTD
  • 1529
« Reply #1 on: July 09, 2004, 05:55:31 pm »
That sounds like waaay too much to me.  My Bentley manual, for an '77-'84 Rabbit/Jetta Diesel, specifies 15 ft-lbs for the flywheel to pressure plate bolts (and no lock-tite required.)
The Pressure plate to crankshaft bolts get 45 ft-lbs, and you use Loctite 270 or 271 on the threads.  These torque specs can be found on page 72, at the end of section "Engine and Clutch".
Jake Russell
Reply #2July 09, 2004, 06:27:44 pm
Mikeyworks
  • 260
« Reply #2 on: July 09, 2004, 06:27:44 pm »
Thanks Jake....I thought that was way too much for such a small bolt.
I torqued the p-plate to crankshaft bolts to spec....and they came with locktite pre-installed.
Thanks again for the advise.
Mikey
Reply #3July 13, 2004, 08:26:56 am
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
« Reply #3 on: July 13, 2004, 08:26:56 am »
Mike, I hope you didn't torque the new style shouldered pressure plate bolts to either 45 lb-ft (too low!) or 74 lb-ft.  The correct procedure for these bolts is 25 lb-ft plus 90 degrees.
Reply #4July 13, 2004, 10:20:02 am
DieselsRcool
  • 152
« Reply #4 on: July 13, 2004, 10:20:02 am »
Quote from: "type53b_gtd"
I suppose these are one time use only also huh?
Reply #5July 13, 2004, 10:54:33 am
type53b_gtd
  • 118
« Reply #5 on: July 13, 2004, 10:54:33 am »
Quote from: "DieselsRcool"
They're supposed to be according to the later Bentleys - however, I've known lots who clean them up and reuse them with new threadlocker.  I have resuded them on occasion myself, but generally buy new ones.
Drew
Reply #6July 13, 2004, 04:24:20 pm
Mikeyworks
  • 260
« Reply #6 on: July 13, 2004, 04:24:20 pm »
I tightened them properly....they're ready to roll....
I am now swapping out the seals and gaskets so I can get the whole thing back together.
I need to clean up and repaint the tranny while I have it out...and swap out the fluid with new good stuff.
I thought about pulling the whole block (especially after seeing some really nicely painted blocks) and painting it and getting it ready for as much show as I hope to get some go from it.
Mikey
