Author Topic: The old blue rebuild (1983 1.6 TD)  (Read 81407 times)
July 22, 2010, 09:13:53 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: July 22, 2010, 09:13:53 pm »
Hello guys my name is Corey i am 20 and this is going to be my first full size rebuild. I might have a lot of questions and thats why im here and to show yall another build project, I know yall like these. I bought this car about 2 months ago with 268,000 Miles on it. I bought it for $275 and then drove it home and even then added 2,000 more miles on the odometer! This is going to be a really really budget build with all the cheapest stuff i can find! ;)
Spec. 1.6L Turbo diesel  broken 5 speed trans. engine code CY Mileage start rebuild 270,012
My plans- 1MM over sized pistons :o, rebuild trans, new valves lifters, new seals and bearings, new timing belt kit, homemade 2.5 inch down pipe.
Well heres both of my cars togather
That down pipe and CV axels are a pain to get apart!
Heres how i got the exgust spring clips off
« Last Edit: September 15, 2011, 07:26:42 am by dankcorey22 »
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1July 22, 2010, 09:18:30 pm
dankcorey22
  • 379
    Cummins!
Re: The old blue rebuild (1983 1.6 TD)
« Reply #1 on: July 22, 2010, 09:18:30 pm »
Heres my new pistons
Hehe thats me doing something
Reply #2July 22, 2010, 09:22:07 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: July 22, 2010, 09:22:07 pm »
I wanna see pics of your tdi! :D
but seriously, nice work. Have you seen anything about my catastrophe that is unfortunately a VW?
that fram filter may or may not give you issues. I got a puralator one once and it restricted the flow so badly it set off my oil pressure buzzer. Shoot for Mann or Bosch.
Reply #3July 22, 2010, 09:22:35 pm
dankcorey22
  • 379
    Cummins!
« Reply #3 on: July 22, 2010, 09:22:35 pm »
Clutch and Flywheel
That little spring that holds the pressure plate on it a pain to get off. i cant imagine how im going to get it back on
Reply #4July 22, 2010, 09:24:20 pm
  • 3468
« Reply #4 on: July 22, 2010, 09:24:20 pm »
Your post tells me that my spring thing is too small for my 210mm clutch... mine from my 200mm clutch went in fairly easy.
well, yours a 210mm that's a bonus! that plus manual steering rack AND AC! you have it all! that engine looks to be in incredible shape.
Reply #5July 22, 2010, 09:26:50 pm
dankcorey22
  • 379
    Cummins!
« Reply #5 on: July 22, 2010, 09:26:50 pm »
Hey man! heres a video of my TDI in the engine bay check it out Overlook of the TDI.3g2  post a link to your failed VW haha
I liked the Fram so far it has not given me any problems
Reply #6July 22, 2010, 11:58:35 pm
arsenicpants
« Reply #6 on: July 22, 2010, 11:58:35 pm »
nice progress :)
looks just like mine ;)
Reply #7July 23, 2010, 01:54:18 pm
dankcorey22
  • 379
    Cummins!
« Reply #7 on: July 23, 2010, 01:54:18 pm »
Got it in the basement on the engine stand
Look the camshaft on the first lobe there is chunks missing
Reply #8July 23, 2010, 03:23:30 pm
dankcorey22
  • 379
    Cummins!
« Reply #8 on: July 23, 2010, 03:23:30 pm »
I have a few questions about the advance pump spring timing. what spring do you supposed to have and when your timing the whole engine do i time it the same as if i had the stock spring in the pump? Thanks alot
Heres my spring out of my pump
Reply #9July 24, 2010, 11:10:59 am
« Reply #9 on: July 24, 2010, 11:10:59 am »
most mk1 cars had manual steering.
most mk2 cars had power steering.
Reply #10July 24, 2010, 09:15:26 pm
dankcorey22
  • 379
    Cummins!
« Reply #10 on: July 24, 2010, 09:15:26 pm »
I have a oil pressure gauge and i need to know the best place to drill and tap a hold for the sending unit.
Reply #11July 24, 2010, 09:34:11 pm
Baron VonZeppelin
« Reply #11 on: July 24, 2010, 09:34:11 pm »
Hey Corey, that 83 looks to be in pretty well kept shape.
Its the only 83 TD that i know about in our state.
Probly at least a couple few others somewhere out here, but they are scarce. Only know of one 84 TD.
Try to TEE off the oil port on the driver side of the cylinder head where the low oil sensor is. A tee will retain the sender too.
That is the lowest pressure/best spot to get reading from.
If it is an electrical gauge - you might can just splice into the wire for the low pressure sender.
Reply #12July 25, 2010, 11:50:35 am
wolf_walker
  • 1205
« Reply #12 on: July 25, 2010, 11:50:35 am »
Good looking project, are you on ncdubs?
Mentat Text Two
Reply #13July 25, 2010, 02:27:07 pm
dankcorey22
  • 379
    Cummins!
« Reply #13 on: July 25, 2010, 02:27:07 pm »
No im not on that but several people has asked me about it. I like to keep it all diesel tho   ;)
Reply #14July 25, 2010, 02:33:13 pm
dankcorey22
  • 379
    Cummins!
« Reply #14 on: July 25, 2010, 02:33:13 pm »
Hey man! thats awesome that its one of few in our state! It is in excellent condition for the year.
Im thinking of a way to TEE off the oil port, i know what your talking about but i dont know how i would tee off of it.
