Author Topic: Tools by location thread  (Read 18977 times)
July 20, 2010, 08:48:25 pm
  • 3468
    • McScrubbins Body Wash
« on: July 20, 2010, 08:48:25 pm »
I was thinking; i have a bunch of tools i had to either make or buy for a very rare job i'm likely to never do again. And i'd love to save someone near by a few bucks by lending them OR to cover costs have a by donation system.
I have the triple square bit for head bolts, i have studs, and the one for CV joints. I also have a clutch centering tool I'm not likely to use again...
So, have a thread in the FAQ that would just be a single post that would group members by area by having links to pages that are FOR that area and if you're in that area you would post in that thread what tools you had up for use.
so for example: in the north western thread i'd post my triple square, CV joint bit and clutch centering tool.  Perhaps even my aluminum post i made for removing valve keepers and what ever else i could find if this actually happened. Even if you're too far like say Calgary from Vancouver or Vancouver to Portland, it would be really cheap shipping to lend a tool.
just a thought.
Also, anyone near me (vancouver/lowermainland) I'd love to borrow a timing gauge for my injection pump! ;D
Abbotsford, Lowermainland, British Columbia
  • 27mm deep socket (injectors)
  • CV joint bit
  • triple square head bolt bit
  • valve keeper removal/install tool
  • clutch centering tool
  • home made intermediate shaft bearing press/puller
« Last Edit: September 02, 2010, 09:16:57 am by Smokey Eddy »
Reply #1July 27, 2010, 09:14:47 pm
commuter boy
  • 277
Re: Should we have a tools by location thread in FAQ?
« Reply #1 on: July 27, 2010, 09:14:47 pm »
I've got a timing gauge and adapter in Burnaby, you're welcome to come by and time it here.  Doesn't take long.
Reply #2July 27, 2010, 09:48:00 pm
catlin_cava
  • 1954
« Reply #2 on: July 27, 2010, 09:48:00 pm »
Atlantic Provinces -
CV Joint Socket
Headbolt Socket
Wide Selection Of Sockets
Mig and Arc Welders
and I also have a boost gauge and connections.
« Last Edit: July 28, 2010, 08:57:39 am by catlin_cava »
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3July 27, 2010, 10:04:35 pm
truckinwagen
  • 1895
« Reply #3 on: July 27, 2010, 10:04:35 pm »
Anchorage, AK
headbolt socket
CV socket
Axle nut socket
pressure/vac gauge for checking fuel line obstructions(very sensitive)
and a bunch more I am sure I am forgetting, but I will update this as I remember.
I am also willing to ship wherever(international too) as long as the tool comes back in a reasonable amount of time.
-Owen
83 Opel Kadett Diesel
Reply #4July 28, 2010, 06:11:55 am
« Reply #4 on: July 28, 2010, 06:11:55 am »
headbolt socket
CV socket
Axle nut socket
timing set
welder and torches :D
I also have many spray guns. I have some orbital sanders for body work as well.
In Central to northeast Ohio
« Last Edit: January 26, 2012, 06:00:23 am by theman53 »
Reply #5July 28, 2010, 11:32:53 pm
Re: Tools by location thread
« Reply #5 on: July 28, 2010, 11:32:53 pm »
Silicon valley California
I have pretty much everything for VW and D24.
OBDII read & reset
pop tester and transfer pressure gauge
Tow/recovery  rig
« Last Edit: July 17, 2011, 04:18:27 pm by 745 turbogreasel »
Reply #6July 29, 2010, 10:03:59 am
« Reply #6 on: July 29, 2010, 10:03:59 am »
Pacific Northwest - North Oregon coast
1.5 head bolt hex bit (10mm)
triple square bits for axle flange bolts, and head bolts.
injector socket
cam lock tool
axle nut socket (the big one)
vw clutch align tool
valve removal tool
trans drain plug tool
drive flange remover/installer
whatever tools i dont have, my local fellow diesel freak has what i dont have, the timing gauge, and all the other special goodies i cant afford. and im sure i left alot of my arsenal off the list.
Reply #7September 01, 2010, 08:08:28 am
lovinthedeez
  • 489
« Reply #7 on: September 01, 2010, 08:08:28 am »
got everything that kev has ^^^^^^^if you're travelling through southern oregon before you hit cali on I-5.
Reply #8March 21, 2011, 06:40:59 pm
macka
  • 957
« Reply #8 on: March 21, 2011, 06:40:59 pm »
mk2 shifter alignment gauge
Quote from: Vincent Walden
Reply #9May 19, 2011, 12:55:35 pm
trav1856
  • 230
« Reply #9 on: May 19, 2011, 12:55:35 pm »
I've got Triple Square Bits in Cushing, OK 6mm - 12mm. I can get 'em for $5 a set (4 bits 6, 8, 10 I think, and 12 for the headbolts) They've been good to me..and I'm still using them. But if you're in the neighborhood and need to tighten/loosen something feel free to lemme know
added:
30mm axle nut socket
engine support bar (in use atm)
Welder (would need some advanced warning. Have pipeline welder and crackerbox)
Added: 11/8/2011
IP timing set (N/A and Turbo)
tranny case lub plug bit (1/2 drive)
several torque wrenches (click type)
« Last Edit: November 08, 2011, 10:05:09 am by trav1856 »
1981 Rabbit Diesel
1981 Cabriolet
Reply #10July 04, 2011, 05:09:11 am
dalek
  • 15
« Reply #10 on: July 04, 2011, 05:09:11 am »
I have the triple squares from 6 to 10mm. I do not know if the VWs use them but I also have a precombustion chamber collar removal tool I used with Mercedes IDI engines... though it needs to be rewelded (I lent it to a machine shop who managed to break it). I also have the tool to remove the idler pulley pin off one of those Mercedes engines. Might get a VW timing tool soon as a friend has a 85 Volvo turbodiesel wagon.
And loads of metric tools.
And a car dolly with a car that has towed a few cars.
Gainesville FL
Reply #11July 16, 2011, 11:40:53 am
« Reply #11 on: July 16, 2011, 11:40:53 am »
injector socket
cam lock tool
vw clutch align tool (big and small)
valve spring compressor
C clamp expander (exhaust)
heater core tester (its a real pain pulling your whole dash out to figure out the core was fine)
mk2 strut nut spanner socket
« Last Edit: November 29, 2011, 08:15:36 am by R.O.R-2.0 »
Reply #12July 16, 2011, 02:46:06 pm
RadoTD
  • 513
    Stage WTF
« Reply #12 on: July 16, 2011, 02:46:06 pm »
I've got a fair number of tools, located in Coquitlam, BC. If anyone around here needs something, don't hesitate to send me a PM!
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #13November 29, 2011, 12:59:58 am
Toby
  • 728
« Reply #13 on: November 29, 2011, 12:59:58 am »
PNW Tacoma WA area
Injector socket
Cam lock plate
IP lock pin
idler pulley pin spanner
VE dial indicator timing tool
Injector tester
Clutch aligning tool
Exhaust C clip remover/installer (clone of factory tool)
6,8,10,12mm 12 point bits
etc., etc., etc.
Reply #14December 10, 2011, 09:18:56 pm
oldpoopie
  • 46
« Reply #14 on: December 10, 2011, 09:18:56 pm »
VCDS
Wheel bearing tools
Timing belt tools
intermediate shaft bearing tools.
Timing belt tension gauge
Injection pump dial indicator
Lots lots more
« Last Edit: December 24, 2011, 09:01:41 am by oldpoopie »
1985 jetta TD. It was free, and it shows. Down and dirty engine refresh made it run fairly well.... No leaks, except water into the cabin!
2001 golf Tdi. Heavy built ALH, soon to have a PD Frankenstein motor.
