Author Topic: 1.6td oil pump interferes with 1.9AAZ block/conrods  (Read 11421 times)
Reply #15July 18, 2010, 12:29:28 am
  • 3468
    • McScrubbins Body Wash
I'm temped to try and modify it with my dremel to make it clear... it just barely hits the pick up tube... clears the windage tray entirely. It's such a weird coincidence that it would just BARELY hit the pick up tube. its not even the tube its self it's hitting but the very edge of the flange (i think?) its hard to tell under the car in the dark with my flashlight.
Reply #16July 18, 2010, 12:47:44 am
truckinwagen
  • 1895
bust out the dremel and go to town!
83 Opel Kadett Diesel
Reply #17July 18, 2010, 01:34:29 am
Check that rod cap isn't on backward, then clearance the flange.
Reply #18July 18, 2010, 01:35:07 am
  • 3468
how do i make sure which way they go???!
Reply #19July 18, 2010, 07:49:08 am
I think if you got the cap to fully seat on the rod then it is on the proper way
Reply #20July 18, 2010, 08:47:49 am
on a 1.6 the side with the "bumps" goes toward the timing belt
Reply #21July 18, 2010, 10:13:57 am
how is a rod cap hitting the pickup flange? its like 2 inches below the crank? least they are on my engines.
Reply #22July 18, 2010, 01:07:34 pm
  • 3468
kevin is yours the AAZ?
the rod cap (the counter weight ON the rod cap) hits the flange part of the tube (where the tube flange joins the pump)
Reply #23July 18, 2010, 02:09:26 pm
AAZ must be WAY DIFFERENT from the earlier engines then. and way different than gasser engines. because my rod caps dont come that close to the oil pump. did you bolt a 1.6 or a 1.9 pump on it? did you loosen the pump to see if you could move it out of the way a little? they do have some wiggle room...
i was just assuming that an AAZ was just like a 1.6 bottom end, just with a tad longer stroke, and bigger bore size, taller block.
Reply #24July 18, 2010, 02:38:45 pm
OM617
Yes, more than bore and stroke alone.
Reply #25July 18, 2010, 10:19:51 pm
  • 3468
yeah apparently. I can see where it was hitting the feed pipe. i HOPE if i grind it down it will clear. No progress today. went to the beach mostly because i really mashed my fingers last night...
Reply #26July 22, 2010, 10:20:27 am
  • 3468
Re: 1.6td oil pump interferes with 1.9AAZ block/conrods
« Reply #26 on: July 22, 2010, 10:20:27 am »
If you found this thread from a search and are wondering what happened, this thread continues on page SIX, reply #81, of this thread.
