Author Topic: What 120 amp alternator is a bolt on upgrade for the stock aaz 90 amp alternator  (Read 4916 times)
July 13, 2010, 07:35:01 pm
srgtlord
  • 797
I would be interested to know what alternator will be a bolt on 120amp upgrade for the aaz engine? ANy help is greatlt appreciated
Reply #1July 14, 2010, 06:33:34 am
GEE-BEE
  • 1604
Non tensioner ,  no a/c type max is 90 amp- ALO 181 X OR ALO187 X
This uses a spring to maintain correct tension
belt is 6pk923
ALO723 X OR  ALO184 X , IS 120 AMP, A/C TYPE, Tensioner type arm /Roller
This unit is fixed and uses a arm roller tensioner
GB
« Last Edit: July 14, 2010, 06:36:27 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
