I was looking at an A2 90 amp alternator and comparing it my A1 non a/c alt. Other than the mounting ears being in the wrong location and the mentioned 6mm : 8mm pivot bolt, I think I can get it to work; The pulley offset is the same. The mount's hole/sleeve can be drilled out to accomadate the later 8mm bolt. Your biggest issue would be finding a non a/c A1 mount.
The link you posted was in a thread I started a few months back. Last night, I mocked the A2 alt in my car mounted in the A1 non a/c mount. I'm not sure if you need the added bracket that mounts to the top of the alt mount and ties to the mount bracket. I figure if the pump/engine mount bracket will support that side of the engine, the stress from tensioning a belt will be trivial. Replace the one pump bolt with a 12.9 grade and it'll be fine.... most likely overkill.
Making the new alt mounting point bar is simple and adding a nice curvature will give it some cosmetic appeal. Replacing the turnbuckle with a reverse threaded heim joint end link will clean things up, although purely cosmetic, also.
My alt was broken in an accident, so I'll be working on getting the A2 alt mounted. Tensioning the alt from the top will be way better than the stock method. It'll save me about $100, too.
-Todd
