Author Topic: Lets have a muffler thread  (Read 27906 times)
Reply #60September 06, 2010, 11:33:40 am
the~boy
  • 14
Re: Lets have a muffler thread
« Reply #60 on: September 06, 2010, 11:33:40 am »
The argument made for trucks is the larger turbos take longer to spool up so small idle/daily driving wont send them to max boost right away.
And that a stock k03 which now is very vocal at 1200 rpm will overheat and die.
But its been fine like this for a few thousand kilometers.
Reply #61September 06, 2010, 01:58:42 pm
  • 3468
    • McScrubbins Body Wash
« Reply #61 on: September 06, 2010, 01:58:42 pm »
Well my advice to you is you could listen to those guys trying to run a business (and the TDI folk who ... i dunno why they say that. possibly because their cars need emission crap or else they have to deal with the ECU business) OR take first hand experience from these guys who have had a straight exhaust on their TD's for tens of thousands of km.
and thanks for the heads up about the jetta! I'll hit it up tomorrow :D
Reply #62September 07, 2010, 03:41:13 pm
  • 3468
« Reply #62 on: September 07, 2010, 03:41:13 pm »
here it is
MOV07223
i know the idle is too high.
« Last Edit: September 07, 2010, 03:45:59 pm by Smokey Eddy »
Reply #63October 03, 2010, 07:17:31 pm
the~boy
  • 14
« Reply #63 on: October 03, 2010, 07:17:31 pm »
Jesus christ, nice set-up.
Reply #64October 03, 2010, 07:26:32 pm
  • 3468
« Reply #64 on: October 03, 2010, 07:26:32 pm »
Your reply has influenced me to make a running video :)
Reply #65October 07, 2010, 08:54:11 am
« Reply #65 on: October 07, 2010, 08:54:11 am »
you dont have a welder do you ed? exhaust clamps suck, but its not like you are running alot of back pressure to make the leaks present themselves..
Reply #66October 07, 2010, 09:29:17 am
gnavs
  • 340
« Reply #66 on: October 07, 2010, 09:29:17 am »
I heart that exhaust!
Reply #67October 07, 2010, 03:37:32 pm
  • 3468
« Reply #67 on: October 07, 2010, 03:37:32 pm »
No welder readily available no. I had a friend who had one and i used it a bunch but he has since found a girl and moved a town away from me. Stopped returning my calls ect. Im sad about not being able to use the welder but ten times more unhappy about losing the friend...
anyways, yes no leaks. Works well. Plus the studs hit the speed bumps before the exhaust tips do. I'd eventually like to weld it.
Curiously enough, when i had the inspection done, they said that the downpipe couldn't be welded to the flex pipe as one piece so i had to cut the flex off and clamp it on both sides...
Thanks Gnavs :)
I can't wait to fix this transmission problem and get a driving video! :D
im just worried the crappy digital camera wont do the exhaust sound justice.
Reply #68October 07, 2010, 03:38:19 pm
  • 3468
« Reply #68 on: October 07, 2010, 03:38:19 pm »
Can anyone spot my Beer Fest trophy in the pile of junk? :)
Reply #69October 08, 2010, 12:06:17 am
« Reply #69 on: October 08, 2010, 12:06:17 am »
that the potato gun sitting next to it?
Reply #70October 08, 2010, 12:07:26 am
  • 3468
« Reply #70 on: October 08, 2010, 12:07:26 am »
yeah it recently went to the dump though
Reply #71October 08, 2010, 06:03:01 pm
« Reply #71 on: October 08, 2010, 06:03:01 pm »
HOT DAMN. This is what I'm doing for exhaust on the 81 TDI ;)
Reply #72October 08, 2010, 08:08:55 pm
  • 3468
« Reply #72 on: October 08, 2010, 08:08:55 pm »
it's really easy to do.
I just removed it to lengthen it by about an inch. it came out of the flex pipe when it scraped along the ground going over a steep bump. What a nightmare :(
don't lower your vw ... its just annoying.
Reply #73October 08, 2010, 08:14:44 pm
RadoTD
  • 513
    Stage WTF
« Reply #73 on: October 08, 2010, 08:14:44 pm »
Don't listen to him! Lower every VW until you can't drive it anywhere, then raise it 1/4" ;)
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #74October 08, 2010, 08:16:36 pm
« Reply #74 on: October 08, 2010, 08:16:36 pm »
That's Absurd.. do not plan on it ;)
