Author Topic: The list is back [photos now fixed]  (Read 4584 times)
June 29, 2010, 04:57:21 pm
  • 1739
« on: June 29, 2010, 04:57:21 pm »
re listing stuff I still have:
Gasser sliver faced cluster. tach doesn't work, so  the perfect opportunity the insert a diesel one and get all fancy.$35
1.6 alternator ,tested $18
1.6 na starter,tested $15
1.9 AAZ alternator ,tested $40 SOLD!
1.6 and 1.9 turbo oil feed lines $15 each
Pick a water pump !1 old style 2 newer all good $10 each 1 SOLD, one of each left
ALH valve cover,$15,vacuum pump $15,coolant flange $7
Mk4 brake master $10 ABS unit $75
Large ridiculous Volvo gasser intercooler, only rated at 15 lbs, but think how much cooling ! $40
ALH block and crank .Very clean but one of the rear mount bosses has been ground to fit into a Mk3 [this is what i was told] .There is a special mount kit for that purpose. However it will fit into a MK4 as is.  $125
and finally a good used 1.9 crank bolt $20  ;D
Every thing of course shipping extra
Cheers
« Last Edit: July 04, 2010, 01:07:46 pm by the caveman »
Reply #1June 29, 2010, 05:23:37 pm
sawedoffgolf
  • 213
Re: The list is back WAIT DON'T BOTHER , I HAVE TO COME BACK AND FIX IT
« Reply #1 on: June 29, 2010, 05:23:37 pm »
Thats a lot of alternators  :P
How is the seal on the ALH valve cover?
Reply #2June 29, 2010, 06:35:58 pm
  • 1739
Re: The list is back [photos now fixed]
« Reply #2 on: June 29, 2010, 06:35:58 pm »
I'll check that cover tomorrow. has anyone finally developed a replacement seal for those ?
Reply #3June 29, 2010, 06:41:38 pm
macka
  • 957
« Reply #3 on: June 29, 2010, 06:41:38 pm »
does the block need work?
Quote from: Vincent Walden
Reply #4June 29, 2010, 06:43:31 pm
  • 1739
« Reply #4 on: June 29, 2010, 06:43:31 pm »
No it looks real good. I will check again before a sale goes through.
Reply #5June 29, 2010, 06:46:45 pm
macka
  • 957
« Reply #5 on: June 29, 2010, 06:46:45 pm »
shipping to P0T2W0?
Reply #6June 29, 2010, 09:07:01 pm
  • 1739
« Reply #6 on: June 29, 2010, 09:07:01 pm »
shipping to P0T2W0?
Will let you know asap
Reply #7June 30, 2010, 05:24:37 am
  • 1739
« Reply #7 on: June 30, 2010, 05:24:37 am »
Let the bidding war begin!
Seriously Macka asked first,so let me give him a shipping quote and if he doesn't want it, you are next.
