Author Topic: Got m-TDI dyno #'s?  (Read 6150 times)
June 27, 2010, 08:48:09 am
punkvideo81
  • 168
Got m-TDI dyno #'s?
« on: June 27, 2010, 08:48:09 am »
Has anyone out there got dyno numbers on an m TDI setup? Or on a nicely modded (giles pump, IC, larger exhaust, pp intake) 1.6 td? I am about to build the latter and was wondering if I could make a _lot_ more power with an m TDI and if I should go that way...
'81 Caddy 1.6 TD
Reply #1June 27, 2010, 09:04:57 am
punkvideo81
  • 168
Re: Got m-TDI dyno #'s?
« Reply #1 on: June 27, 2010, 09:04:57 am »
An AHU tdi...
'81 Caddy 1.6 TD
Reply #2June 27, 2010, 12:46:09 pm
  • 1739
« Reply #2 on: June 27, 2010, 12:46:09 pm »
Well when i had my 98 AHU chipped and with big nozzles would have had 245 ft'lbs of torque, 142 hp at the wheels. So a mTDI without the EGR and big nozzles and no other mods should be close to that? Then more boost and away you go....
Reply #3June 28, 2010, 11:50:12 am
« Reply #3 on: June 28, 2010, 11:50:12 am »
TDI engines are capable of more power just because of the way they burn their fuel, and they run quite a bit lower compression than an IDI engine.
Reply #4June 28, 2010, 12:56:34 pm
« Reply #4 on: June 28, 2010, 12:56:34 pm »
or throw a big turbo and loads of fuel at a TDI and have over 300 whp. lol..
if you have a TDI at your disposal, just use it, otherwise use the 1.6
