My slow AAZ rebuild
4
5
6
Topic: My slow AAZ rebuild (Read 28225 times)
June 18, 2010, 05:04:00 pm
gnavs
My slow AAZ rebuild
June 18, 2010, 05:04:00 pm »
I'm really not sure why I didn't post my progress on here, I'd rather get some technical advice than a bunch of "do work son", so here is what I've been up to the last 6months or so
*November 2009*
So after dealing with above average oil consumption, coolant leaking into unknown and potentially damaging areas I've decided to tear into the diesel and start replacing some stuff. I'll be doing the headgasket, timing belt and, if the funds allow it, slap a new T3 on it as well. This is my first time getting this involved with anything really so progress will likely be slow but I'm looking forward to learning some things.
Here's how it looked in 08
And here's what it looks like as of an hour ago.....
Last Edit: August 20, 2014, 01:58:35 pm by gnavs
June 18, 2010, 05:06:08 pm
gnavs
Re: My slow AAZ rebuild
June 18, 2010, 05:06:08 pm »
Getting the 12 year old crud off of everything was maddening
*January 2010*
Here is my current workstation
dirty engine pics :shock:
June 18, 2010, 05:07:10 pm
gnavs
June 18, 2010, 05:07:10 pm »
A few parts were ordered....
*January 23, 2010*
Passat style PD150 intake manifold
Rover boost pin
June 18, 2010, 05:09:03 pm
gnavs
June 18, 2010, 05:09:03 pm »
Yup, cleaning was definitely time consuming...
*February 11, 2010*
A few more updates, I got the head off and discovered the usual cracks between the valves. Apparently it's pretty common so I'm not too worried.
On to the current pictures. She's a dirty old girl...
definitely looks like I've got some oil blowing by pistons 2 and 3 so a re-ring is in order as well.
June 18, 2010, 05:09:44 pm
gnavs
June 18, 2010, 05:09:44 pm »
*February 16, 2010*
Out with the old, in with the new
June 18, 2010, 05:10:49 pm
gnavs
June 18, 2010, 05:10:49 pm »
*February 17, 2010*
Finally got around to getting the valves removed. I ended up getting the one from Princess Auto and it worked fine. Next up is getting the head and block hot tanked but I don't know who does this.
The crank nose will end up getting machined for the TDI pulley.
On to the pics
June 18, 2010, 05:11:31 pm
gnavs
June 18, 2010, 05:11:31 pm »
*February 27, 2010*
Head and block back from the hot tank. The block didn't quite come as clean as I wanted so I'll have to get at it with a wire wheel before paint. The cylinder head has the expected cracks between the valves but I think they'll be alright.
Meanwhile the pistons are taking a varsol bath overnight.
and here's the color I'm going for...
June 18, 2010, 05:12:10 pm
gnavs
June 18, 2010, 05:12:10 pm »
*March 5, 2010*
since the hot tanking didn't get the block as clean as I wanted it, I decided to take my dremel and a few sanding drums to it, I think it came out quite nicely. Decided to go with a cast iron color for paint, pics of the fresh painted block should be up soon
June 18, 2010, 05:12:53 pm
gnavs
June 18, 2010, 05:12:53 pm »
*March 22, 2010*
My fresh Autometer EGT and boost gauges came in last week. Also lost my job last week. Makes for more time but less $$.
I hate the look of A Pillar pods and also the "look at me!" aspect to them so I decided to put them where they'd make the most sense, right in front of my face.
I used 2" ABS plastic pipe which holds standard gauges ever so gently. Still needs some sanding and painting but the idea gets across. It clears the hazard light switch perfectly and doesn't block the odometer or anything.
June 18, 2010, 05:13:53 pm
gnavs
June 18, 2010, 05:13:53 pm »
And here we are, completely caught up to todays progress
*June 18, 2010*
Progress once more.
Installed the Rover pin in my injection pump, went in super easy (that's what she said), painted and cleaned up some stuff, and finally got my scratched crank machined.
It might have been unnecessary but the peace of mind should be worth the coin.
Set of undersized main and rod bearings alongside
Freshly painted and gasket matched PD150 intake
Tapped my exhaust mani for the EGT probe, yes I know it's crooked
went with a cast iron color for the block and head
aaaand cleaned up the valves
up next, hone the cylinder walls and start putting the bottom end back together.
Last Edit: August 20, 2014, 03:28:08 pm by gnavs
June 18, 2010, 05:16:23 pm
June 18, 2010, 05:16:23 pm »
Congrats senior!! Looookin goood!
Reply #11
June 18, 2010, 06:25:37 pm
ricosuave
Reply #11 on:
June 18, 2010, 06:25:37 pm »
hey dude, thats looking great
let me know if you ever need a hand, would love to see some of your work in person!
Now: 00 2dr Golf TDI, 03 Jetta Wagon TDI, 02 2500HD Duramax -
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI -
"Everything I save by driving diesel I put back due to poor German engineering and crappy Mexican workmanship!"
Reply #12
June 18, 2010, 06:31:17 pm
GEE-BEE
Reply #12 on:
June 18, 2010, 06:31:17 pm »
Got blue or red aaz engine hoses for yah when ready...
I sent your body coolant hoses to the tooler
Wear gloves...
Gb
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #13
June 18, 2010, 06:31:49 pm
gnavs
Reply #13 on:
June 18, 2010, 06:31:49 pm »
Rick! long time no see, I'll definitely let you know when its a progress day
Reply #14
June 24, 2010, 10:54:52 am
gnavs
Reply #14 on:
June 24, 2010, 10:54:52 am »
Yesterday my G60 valve cover arrived in the mail and now I've set about making damn sure it's possible to run it on an AAZ head before I start drilling and tapping. Can I get confirmation from you veterans?
4
5
6
My slow AAZ rebuild
