S-PAutomotive.com
Author Topic: a couple questions bottom end bearings and seals  (Read 1630 times)
June 16, 2010, 09:12:23 pm
  • 3468
    • McScrubbins Body Wash
« on: June 16, 2010, 09:12:23 pm »
How do you remove the IM shaft bearings on the AAZ?
Also,
I think i broke the retainer that holds the seal for the crank shaft on the AAZ block. The 1.6TD MF one bolts up to it and has the same seal as in my seal replacement kit.
Can i use the 1.6td one?
also. which direction does it go in/out?
Reply #1June 16, 2010, 09:22:02 pm
  • 9005
Re: a couple questions bottom end bearings and seals
« Reply #1 on: June 16, 2010, 09:22:02 pm »
Did you break the front or rear seal carrier?
I think Andrew has a DIY in the FAQ on the IM bearings.
Reply #2June 16, 2010, 09:22:46 pm
  • 3468
« Reply #2 on: June 16, 2010, 09:22:46 pm »
the one that goes to the transmission.
Reply #3June 16, 2010, 09:24:27 pm
  • 3468
« Reply #3 on: June 16, 2010, 09:24:27 pm »
found it here
Cheers.
S-PAutomotive.com
