Author Topic: changing cv joints  (Read 9336 times)
June 15, 2010, 08:05:53 am
dyoungen
  • 128
changing cv joints
« on: June 15, 2010, 08:05:53 am »
How much trouble is changing a complete cv joint? Both sides have leaking boots. I have a 1985 Jetta na Diesel with a 5 speed.
Reply #1June 15, 2010, 09:44:02 am
Re: changing cv joints
« Reply #1 on: June 15, 2010, 09:44:02 am »
You mean changing the whole axle as a unit or both CVs?
Reply #2June 15, 2010, 10:02:11 am
« Reply #2 on: June 15, 2010, 10:02:11 am »
I'm assuming outter boots is what you want to change? if so, the cv joint just pops off the end of the axle and you slide on a new boot.
Reply #3June 19, 2010, 08:27:28 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #3 on: June 19, 2010, 08:27:28 am »
"Mr Haynes, I presume?" :D
Hmm.............The god of greasy things must like you! ;D
And there is me using an armco post by the road to pound the sodding thing off!
« Last Edit: June 19, 2010, 08:29:08 am by smutts »
Reply #4June 19, 2010, 08:38:53 am
« Reply #4 on: June 19, 2010, 08:38:53 am »
No the yreally do ;) Personal Experience. lol
Reply #5June 19, 2010, 09:13:13 am
« Reply #5 on: June 19, 2010, 09:13:13 am »
the CVs just pop off the end of the axle? hows this? mine never just pop off.
Reply #6June 19, 2010, 03:20:52 pm
« Reply #6 on: June 19, 2010, 03:20:52 pm »
There only a pressure fit, there always sandwiched in between the steering knuckle and the wheel nut. They aren't on there with any thing. A few light to medium raps around the inside of the outer cv pops it off :P
Reply #7June 19, 2010, 04:50:52 pm
lovinthedeez
  • 489
« Reply #7 on: June 19, 2010, 04:50:52 pm »
actually, there is a snap ring inside of the joint on the axle..... :-*  it needs to be pounded off
Reply #8June 19, 2010, 10:24:57 pm
« Reply #8 on: June 19, 2010, 10:24:57 pm »
Inner joint maybe, but the outer joints just pop off. done it to two axles to swap the outers when one grenaded.
Reply #9June 20, 2010, 06:52:05 am
« Reply #9 on: June 20, 2010, 06:52:05 am »
my outters never slip off.. and my inners are held on with a spring clip. never tried to remove an outter tho. they have never just popped apart for me.
Reply #10June 20, 2010, 09:20:22 am
« Reply #10 on: June 20, 2010, 09:20:22 am »
Inners are held on, outters pop off ;)
Reply #11June 20, 2010, 03:16:34 pm
MJF
  • 581
« Reply #11 on: June 20, 2010, 03:16:34 pm »
Older mk1 has snap ring that holds outer cv. Newer has a spring clip that pops off.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #12June 20, 2010, 06:51:23 pm
dyoungen
  • 128
« Reply #12 on: June 20, 2010, 06:51:23 pm »
I'm planning on changing the complete cv joints, axels and boots, everything. The boot on the passenger side looks like it's been split for awhile and I figure if ones going to be replaced, I might as well do both. I don't believe in waiting till the axel falls off, I figure if that's going to happen, it'll happen at the worst time so I'll do both when I"M ready. Thanks guys, you've convinced I'll be able to try it and succeed.
Reply #13June 20, 2010, 07:21:49 pm
« Reply #13 on: June 20, 2010, 07:21:49 pm »
if your replacing the entire axle as a whole unit, its real simple.
Can't remember the size of the axle nut.. possibly 1 1/16" no thats injectors i think.. 1 1/4" maybe.. and then the 6 or 8 8mm 12 point bolts on the inner joints. turn the wheel to the far extreme of its travel and the axle should slide out. Removing the front control arm bolt will give you an extra 1" or so of room to play.
Reply #14June 20, 2010, 07:41:20 pm
« Reply #14 on: June 20, 2010, 07:41:20 pm »
axle nut is 30mm ... I just had to buy one as I lost my other 30mm.
