Author Topic: so i have a mk1 coupe td, and i'd like to drive it  (Read 20304 times)
Reply #30January 25, 2011, 06:40:58 pm
Re: so i have a mk1 coupe td, and i'd like to drive it
« Reply #30 on: January 25, 2011, 06:40:58 pm »
yep i live in york
Reply #31January 25, 2011, 07:08:14 pm
« Reply #31 on: January 25, 2011, 07:08:14 pm »
boiling definitely helps, i'm not quite sure its worth the hassle, but to get them perfectly awesomely clean i think boiling them works well, the carbon comes off super easy after that, the baking soda helps but still takes work to get them off, if anyone has suggestions or wants to tell me something i am doing wrong please tell me
cook up a tasty snack
the water was black when this one was done
far left was the one i boiled, the rest were just soaked in baking soda, scrubbed with a brushed and cleaned with a tooth brushed, rubbed down all over with a rag, cleaned the ring lands out with a broken ring, i've been told thats a bad idea, but i did it anyway haha, the still need a bit more
tops, i think i will go over these a bit more
here is a nick i noticed, not quite sure what i am going to do about it
ring lands of the boiled piston, definitely better than the others
ring land of one i didn't boil, pretty good but could be better
piston on the left is from cylinder #3, on the right is #4 to compare, cylinder 3 is the one where the head cracked, u can see the injection pattern deal is wider and the carbon didn't come off that side so well
Reply #32January 27, 2011, 08:32:42 pm
« Reply #32 on: January 27, 2011, 08:32:42 pm »
so i left them sit with baking soda paste on them again, then cleaned them all over with the tooth brush again, they're starting to look almost new, i'm gonna do this again and they will look almost new by then,  you can really see the difference much better on cylinder 3 where the spray pattern is much wider, and a lot more discolored and turned kind of blue, so its obvious that it was much much hotter in that cylinder
Reply #33January 29, 2011, 12:07:33 am
Rabbit TD
  • 840
« Reply #33 on: January 29, 2011, 12:07:33 am »
On valves and piston tops most people just use a wire wheel on a bench grinder.  Try your piston boiling thing and then your broken ring or groove cleaner for the grooves. Hell I've actualy seen people use hacksaw blades before but I imagine it put some extra clearance wheree it wasn't wanted.  Don't use the wire wheel in the grooves either, just the tops.  I'd be lost without that wheel to clean things.
Reply #34January 29, 2011, 06:09:24 am
« Reply #34 on: January 29, 2011, 06:09:24 am »
If it is a standard piston for 1.6 *not reading again sorry* I have my set of 4 if that knick bothers you too much :D
Reply #35January 29, 2011, 06:20:45 am
« Reply #35 on: January 29, 2011, 06:20:45 am »
yeah the valves didn't really get all that clean, the bottom did, but the top has some hard chunks on it, these pistons are 20 over
Reply #36January 31, 2011, 03:42:17 pm
« Reply #36 on: January 31, 2011, 03:42:17 pm »
think i might boil number 3 again it still has small bits here and there
Reply #37February 05, 2011, 02:42:46 pm
« Reply #37 on: February 05, 2011, 02:42:46 pm »
been working on porting here and there as i have time, just gasket matching and cleaning things up, i wanna try to take the harshness out of the turn in the exhaust ports but its hard to get in that angle
the set up
look how much the exhaust needs opened up holey moley
the intake and what i have done so far, just cleaned it all and smooth transitions i'm not gonna mess with the guide hump just run over it to resurface
stock intake
Reply #38February 06, 2011, 03:14:30 pm
« Reply #38 on: February 06, 2011, 03:14:30 pm »
while i was working on my daily i did a few things on the car itself.  front poly bushings and coil overs, not lowered down or anything
Reply #39February 06, 2011, 03:50:15 pm
« Reply #39 on: February 06, 2011, 03:50:15 pm »
Looks good.
About how long did it take to port each runner?
What coilovers are you using?
Reply #40February 06, 2011, 04:25:02 pm
« Reply #40 on: February 06, 2011, 04:25:02 pm »
i only did 2 so far haha, takes a long time and you gotta be really really careful, you can't monkey around too much in the bowl area, i just cleaned everything up and gasket matched, i would say about an hour per port.  maybe so people work faster, but i wasn't in a hurry i am trying to be carful u know.  has weitec xs coil overs i believe, they are the fully adjustable ones. i bought them probably 6 years ago, been collecting dust since then.
Reply #41August 05, 2011, 07:24:32 pm
« Reply #41 on: August 05, 2011, 07:24:32 pm »
well, its been eons since i posted in here, i finally finished porting the head, and took it to the machine shop.  When i ported the head, i gasket matched all the ports, and then sanded the whole way down the ports to remove all the casting marks, and to resurface everything down the port.  around the valve seat you make the aluminum part of the port all match the valve  seat, and then again do the same thing, resurface everything and clean up any boogers or casting marks.  on the exhaust ports i tried to remove how harsh the turn is.  the guy at the machine shop said it looked good, but they could have done it much more quickly haha, and they have a machine that opens up the valve seat area.
anyways porting really can make a big difference, just by examining the area, lets say u have a 25mm port that is a perfect circle.  you then have an area of 491mm squared.  so lets say gasket matching adds .5mm all the way around and u now have a 26mm port.  and yes i probably removed a tleast a mm to gasket match the exhaust ports.  so a 26 mm port would have an area of 531mm squared.  thats an increase of the area of flow of nearly 10%.  theres a million other factors when it comes to how much a head can flow,  but its a perfect example of how such a minor difference can increase the flow rate of the head in a significant way.
more updates as i progress, assuming that i continue to progress haha
Reply #42August 07, 2011, 07:45:23 pm
jb86
  • 102
« Reply #42 on: August 07, 2011, 07:45:23 pm »
i read thru the posts on boiling in baking soda and h2o
i fly r/c airplanes.
ive read on r/c forums about cleaning the engines
im not sure the exact steps
but i think it was use an old crock pot, set on low or some other setting
full with anti freeze
over night
the parts come out clean
very clean
in the morning.
i went to rcuniverse. typed in search - antifreeze clean.
http://www.rcuniverse.com/forum/m_326599/anchors_326599/mpage_1/key_/anchor/tm.htm#326599
this may help
jon
Reply #43August 07, 2011, 08:03:02 pm
« Reply #43 on: August 07, 2011, 08:03:02 pm »
haha i was reading where it said put the whole engine in the crock pot, i was thinking wtf, then i remembered rc plane.  thats an interesting idea to try, honestly boiling the pistons hardly did ***, letting them sit covered in backing soda paste worked quite well tho, took a couple days but only maybe an hours worth of work total.
Reply #44August 08, 2011, 01:03:03 am
Mark(The Miser)UK
  • 1557
« Reply #44 on: August 08, 2011, 01:03:03 am »
I wouldn't worry about that nick down by the oil ring, too far down to matter much, but mark it with a spot of felt tip, and avoid aligning middle ring gap with it to be sure.
Mark-The-Miser-UK
