Author Topic: Land Rover 300tdi pump  (Read 7626 times)
June 09, 2010, 09:14:52 am
dh13
  • 108
« on: June 09, 2010, 09:14:52 am »
Hi,
So I just bought myself a AHU for my 1983 toyota hilux. My plans are a mTdi build, but I just can't justify the cost of a super pump from Giles at this point in time. I know it sounds stupid but because I have to source a AAZ pump and a AHU pump then send them to him the cost of the pump alone is well over $2000.
I have found a brand new 300tdi pump, but am concerned about it not having the true LDA. From what I have read some pumps came with a "fake" LDA, the same as the some of the later AAZ pumps.
I don't know if there is any way to tell from the numbers on the pump but here they are;
0 460 414 098
R 509
ERR 4419
586 701767
1027109
All I need to know is if this pump has the correct LDA. I notice that the pump has a boost input port at the top, which to be says that it is a true LDA, but I don't know for sure.
Anything helps
Thanks
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #1June 09, 2010, 11:36:32 pm
svenakela
  • 89
Re: Land Rover 300tdi pump
« Reply #1 on: June 09, 2010, 11:36:32 pm »
You could check my pictures, seems the serial number is pretty close to mine.
http://www.vwdiesel.net/forum/index.php?topic=22623.0
I think you should go for it, if something needs to be changed parts are interchangable.
(Or http://switchamotor.blogspot.com :) )
« Last Edit: June 10, 2010, 11:11:16 am by svenakela »
Reply #2June 10, 2010, 09:44:52 am
rolo
  • 40
« Reply #2 on: June 10, 2010, 09:44:52 am »
Used this pump on mine but put a bosch lda from a rover maestro on it, straight forward. Was ok as was but doing the govenor mod the maestro has stronger springs
the last one
Reply #3June 10, 2010, 11:42:45 am
dh13
  • 108
« Reply #3 on: June 10, 2010, 11:42:45 am »
Well I ordered the pump. I hope it works out. Although I wont have the engine running for awhile.
Thanks
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #4June 10, 2010, 08:08:20 pm
blackdogvan
  • 574
« Reply #4 on: June 10, 2010, 08:08:20 pm »
Having bought a few LR 300 mech pumps, i've yet to see one without a full & proper LDA. These are the pumps that have the rover boost pin many vendors sell for aaz upgrades. Don't worry about the elect bit on the throttle shaft, its just a throttle position sensor you can pitch.
1991 Vanagon 1.9 mTDI
Reply #5June 11, 2010, 02:12:00 pm
dh13
  • 108
« Reply #5 on: June 11, 2010, 02:12:00 pm »
Sweet. Well I just paid for the pump and it should be here is a week or so.
1991 Jetta 1.6TD
1980 Caddy 1.6TD
