Author Topic: Is a VNT possible in a mk2 jetta  (Read 7324 times)
Reply #15June 14, 2010, 11:24:06 am
Re: Is a VNT possible in a mk2 jetta
« Reply #15 on: June 14, 2010, 11:24:06 am »
but im assuming he already has a US spec VNT. and probably wants to put it on a mk2..
Just comparing incase someone alse has those measurements.
Reply #16June 16, 2010, 07:37:35 am
« Reply #16 on: June 16, 2010, 07:37:35 am »
could someone get me the measurements from the exhaust / intake surface on the head to the centerline of the VNT 17 and the relationship from the deck surface to how far up/down the centerline of the intake of the turbo? Not a bad run on sentence eh? Let me know if it makes sense to you...basically a vertical and horizontal measurements from a known location on the block to the center of the turbo inlet.
Wouldn't be bad to know the OD of the turbo inlet either :D
Reply #17June 16, 2010, 10:06:50 am
« Reply #17 on: June 16, 2010, 10:06:50 am »
US or Euro spec VNT? i have a us spec vnt bolted to my 1.5 sitting on the floor...
Reply #18June 16, 2010, 03:52:05 pm
« Reply #18 on: June 16, 2010, 03:52:05 pm »
US...I think I could get away with a euro as is. But parts for them are a pain from what I gather. The US 17 is what I eventually want to run. If you can let me know where the intake is in relation to the engine so I can repeat it that would be awesome.
Reply #19June 22, 2010, 06:14:52 am
« Reply #19 on: June 22, 2010, 06:14:52 am »
Could you take a square to the oil pan up to the intake for that VNT. Let me know where the center is and I will be good. A picture from the TB side of the engine would be great to. Pretty square to the side of the engine too. I want to make this before I get the VNT so it will be and easier add:D
