Author Topic: Ceramic coated vs. stainless  (Read 12431 times)
December 05, 2005, 12:25:02 pm
935racer
« on: December 05, 2005, 12:25:02 pm »
I am wondering what more people would be interested in, ceramic coated mild steel DP's or stainless DP's. Please feel free to add your opinions to the pros and cons of both. The ceramic coated versions will be cheaper than the stainless versions.
Reply #1December 05, 2005, 12:46:33 pm
BlackTieTD
  • 1512
« Reply #1 on: December 05, 2005, 12:46:33 pm »
ceramic. will the ceramic hold up to corrosion as well as stainless though? that is my only concern.
Reply #2December 05, 2005, 03:40:49 pm
935racer
« Reply #2 on: December 05, 2005, 03:40:49 pm »
The ceramic coat should hold up to corrosion very well as long as it is not being sandblasted from road debris. The thing about downpipes is that they are in the engine bay and shouldn't see abuse except from heat which the ceramic coat is more than capable of taking. Also our downpipes are made from aluminized steel, which doesn't really rust.
Reply #3December 05, 2005, 04:15:28 pm
  • Administrator
  • 1156
    • Malone Tuning Ltd.
« Reply #3 on: December 05, 2005, 04:15:28 pm »
Quote from: "935racer"
In that case an exhaust wrap could easily be used for peace of mind. Inexpensive too.
I voted for ceramic coating by the way.
http://www.tunezilla.com
93 Eurovan AHU TDI
97 Golf Variant Syncro 1.9L 1Z TDI - sold and missed
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #4December 05, 2005, 07:17:47 pm
3beejay3
« Reply #4 on: December 05, 2005, 07:17:47 pm »
I chose stainless
A good stainless DP will last at least 8-10 years minimum.
Ceramic coating is OK but it just delays the inevitable.
In the long run stainless would very likely be cheaper.
BJ
Reply #5December 05, 2005, 07:22:00 pm
tmaybee
  • 13
« Reply #5 on: December 05, 2005, 07:22:00 pm »
I would like stainless.
Now, how about ceramic coated stainless?
Reply #6December 08, 2005, 12:15:42 pm
BlackTieTD
  • 1512
« Reply #6 on: December 08, 2005, 12:15:42 pm »
any idea on pricing or timing?
Reply #7December 08, 2005, 02:36:52 pm
935racer
« Reply #7 on: December 08, 2005, 02:36:52 pm »
Still hoping more people would cast out some opinions, I can start offering ceramic coated versions now as in tomorrow for and additional $40USD. The vendors section sure doesn't get much traffic.
Reply #8December 08, 2005, 04:31:08 pm
Justin
  • 455
« Reply #8 on: December 08, 2005, 04:31:08 pm »
is that for coated inside of the down pipes as well?
www.archeryprostaffmi.com
Reply #9December 08, 2005, 06:25:00 pm
Master ACiD
  • 328
« Reply #9 on: December 08, 2005, 06:25:00 pm »
i like stainless. ceramic coatings are only good untill the first rock chip. then 2 years later theres a big rust hole.  all it takes is 1 little rock chip to run the whole shebang.
Reply #10December 08, 2005, 08:59:21 pm
935racer
« Reply #10 on: December 08, 2005, 08:59:21 pm »
Just so everyone knows, the downpipes are made form alumized steel, I had a piece of it sitting out back for the better part of 2 years in our really rainy climate. And there isn't really any rust on it. The only thing that is likely gonna rust on these downpipes would be the welds and the flanges. However with the ceramic coating I can't imagine one rusting out in uder 10-15 years.
Reply #11December 15, 2005, 09:51:41 am
BlackTieTD
  • 1512
« Reply #11 on: December 15, 2005, 09:51:41 am »
Paypal sent :)
Reply #12April 30, 2006, 12:29:38 am
« Reply #12 on: April 30, 2006, 12:29:38 am »
I would be more interested on the coating of the inside of the manifolds as well as downpipes.  Wouldnt this keep exhaust temperature where its needed?  As for the outside, couldn't a protector of some sort be put to protect the ceramic coat?
Reply #13April 30, 2006, 01:46:40 am
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #13 on: April 30, 2006, 01:46:40 am »
agreed. stainless pipe, with multiple ceramic coatings on the inside only. If you can prevent heat from making it into the pipe walls, no need for an exterior coating.
I chose option 'C'. Both.
Reply #14May 02, 2006, 06:52:54 pm
derek510galaxy
  • 9
« Reply #14 on: May 02, 2006, 06:52:54 pm »
Might need to consider the vibration factor too... nearly any stainless alloy will be more brittle than mild steel and therefore more prone to crack in a diesel application, especially if there are too few supports.
1979 Rabbit TD (in the works)
1983 Rabbit GTI (350,000 miles)
Fixmyvw.com
