Author Topic: 1.9 td EGR  (Read 11345 times)
May 22, 2010, 06:52:47 pm
salutka
  • 8
1.9 td EGR
« on: May 22, 2010, 06:52:47 pm »
Hi, I'm almost done with my MK2 conversion and I have a few questions about the EGR system on a 1997 1.9 TD (AAZ). I have tried to block off the EGR, by installing a plate between the valve and exhaust pipe (see attached picture), but the engine refuses to start with the plate in place. Also, none of the engine vacuum lines have been installed except for the brake booster. Does anyone have any info on the subject?
Thank you.
Reply #1May 22, 2010, 07:02:24 pm
Re: 1.9 td EGR
« Reply #1 on: May 22, 2010, 07:02:24 pm »
Will it start with the plate removed?
Did you see this engine running?
Try putting 12v to the stop solenoid.
Reply #2May 22, 2010, 07:08:26 pm
salutka
  • 8
Re: 1.9 td EGR
« Reply #2 on: May 22, 2010, 07:08:26 pm »
The moment I remove the plate the engine starts immediately. It still runs a little rough at idle but I'm guessing it's because the egr vacuum lines are not connected. Oh and there is a vacuum actuator behind the pump that I can't identify (not the one going to the turbo.)
Reply #3May 22, 2010, 07:14:09 pm
Re: 1.9 td EGR
« Reply #3 on: May 22, 2010, 07:14:09 pm »
Try putting 12v from the battery to the stop solenoid and see if it will start with the plate in place.
Your air filter isn't completely plugged up is it?
Reply #4May 22, 2010, 07:20:15 pm
salutka
  • 8
Re: 1.9 td EGR
« Reply #4 on: May 22, 2010, 07:20:15 pm »
No my air filter is brand new, and what is the stop solenoid? Is it the 12V line at the fuel pump?
Reply #5May 22, 2010, 07:21:35 pm
salutka
  • 8
Re: 1.9 td EGR
« Reply #5 on: May 22, 2010, 07:21:35 pm »
Do you mean the wastegate hose?
Try pulling the hose between turbo and intake manifold and see if it starts then with the EGR plugged.
Reply #6May 22, 2010, 07:22:00 pm
Re: 1.9 td EGR
« Reply #6 on: May 22, 2010, 07:22:00 pm »
Yes. Not the one on the side of the pump though.
Try Andrew's suggestion first though if it's easier. I believe he means the boost hose that feeds the engine all it's air, not the small one going to the LDA
Reply #7May 22, 2010, 07:29:36 pm
salutka
  • 8
Re: 1.9 td EGR
« Reply #7 on: May 22, 2010, 07:29:36 pm »
Ok thanks guys I'll try that out on Tuesday and keep you posted. One more thing, do you guys know where I can find the electrical diagram for the EGR system, I tried looking on mitchell but they don't seem to have it. If not I'll go see a VW shop.
Reply #8May 22, 2010, 07:36:47 pm
Re: 1.9 td EGR
« Reply #8 on: May 22, 2010, 07:36:47 pm »
I would suspect the mk3 Bentley would cover it but I'm not sure. Maybe Vince knows.
Reply #9May 22, 2010, 08:03:03 pm
macka
  • 957
Re: 1.9 td EGR
« Reply #9 on: May 22, 2010, 08:03:03 pm »
yea I think it does, although my copy is at home
Quote from: Vincent Walden
Reply #10May 22, 2010, 09:56:07 pm
Re: 1.9 td EGR
« Reply #10 on: May 22, 2010, 09:56:07 pm »
Unfortunately the standard MK3 Bentley doesn't cover the EGR system very well... and the electrical part of it really really poorly imho.
There's a specific Bentley for the early Passats that supposedly does much better, but last I checked it was only available in electronic format for over 100 bucks.  :o
If you have specific questions we may be able to help you out... those of us graduates of the School Of Hard Knocks.   :D
Reply #11June 21, 2010, 12:52:46 pm
salutka
  • 8
Re: 1.9 td EGR
« Reply #11 on: June 21, 2010, 12:52:46 pm »
Well I think I figured out the problem, the wastegate valve's internal shaft broke, now the wastegate is stuck closed, giving me 100% boost at all times.
Reply #12June 21, 2010, 09:53:41 pm
Re: 1.9 td EGR
« Reply #12 on: June 21, 2010, 09:53:41 pm »
that makes no sense as to why it wont start with the egr blocked. wastegate should have nothing to do with it. im wondering if the intake isnt plugged up?
Reply #13June 22, 2010, 09:29:08 pm
Henchman
  • 183
Re: 1.9 td EGR
« Reply #13 on: June 22, 2010, 09:29:08 pm »
That is probably for cruise control.
It's out there if you look for downlowad, not that I condone that!
This would only be an issue at high boost, idol you aren't making boost.  Did you pull the intake to see the level of cocking?  I've pulled somes and have been almost completely bloc ked
Thank you.
Is this an actuall picture of your engine bayÉ
Ian
Reply #14June 24, 2010, 09:10:32 am
salutka
  • 8
Re: 1.9 td EGR
« Reply #14 on: June 24, 2010, 09:10:32 am »
No it's not the the actual picture, just got one from google, anyways I got a newer jetta that's in alot better shape that i'll be using for my project. I'll be pulling out my AAZ soon and replacing the turbo with a new one. I'm going to wait this fall after school is over to start working on my project. Thank you so much for all your help, I'm gona post lots of picture's of my project during the build, see you this fall!
