Author Topic: jetta coupe #2 finally becomes TD jetta coupe #2  (Read 2388 times)
May 13, 2010, 05:58:47 pm
2mAn
« on: May 13, 2010, 05:58:47 pm »
i used to have an 84 coupe that i turbo'd. it was a ton of fun, but i was deep in debt and i had to sell it.  :'(  i missed it, especially when i saw what the new owners were doing to it. recently i swapped in a 16v motor along with a 2H transmission and had plans to swap in a TD into another car shortly. well i got tired of the 16v quickly and once i had the chance i pulled the sucker out and installed another diesel. its the 11mm block, originally NA but has a full factory TD setup.
im so excited to be back! and now, some pics
you see my other jetta coupe in the backround. inarisilver 1980 coupe. it will get a rebuilt JH motor along with the 2H transmission. 16v is going into a rabbit and will get a nice (16G) snail on it.
this is my daily so its gotta have the best mpg, the looks are less important to me, though i do think shes rather sexy :-*
and heres a current image of where im at. a couple more hours and it should be running  ;)
Reply #1May 13, 2010, 06:57:05 pm
redneck_vdub
  • 80
Re: jetta coupe #2 finally becomes TD jetta coupe #2
« Reply #1 on: May 13, 2010, 06:57:05 pm »
Looks pretty clean from what i can see! Great work! Im lovin the stance on that thing.
'01 Golf TDI "The Redneck V-Dub"
360,000kms on the body; 17,000kms on the engine :D
EGR delete, 2.25" turbo back, air box mod, Giles injectors, VNT 17, ARP headstuds, 14LB flywheel, boost and EGT gauges.
Oo=w=oO
Reply #2June 16, 2010, 12:00:41 pm
2mAn
« Reply #2 on: June 16, 2010, 12:00:41 pm »
so far everythings been going good. Im in the process of getting all the extra gauges installed that i need, including egt, boost and oil temp. fun fun funnnnnn
still trying to get the fuel filler neck to accept the diesel fillers, what a pain
Reply #3June 16, 2010, 01:02:51 pm
lovinthedeez
  • 489
« Reply #3 on: June 16, 2010, 01:02:51 pm »
so is it running yet at least?  I told this that it was gonna go in a diesel, and it grinned from side to side.   ;D
