Author Topic: Performance IDI 1.6/1.9 Hydraulic camshafts now in stock and ready to go!  (Read 116718 times)
Reply #60November 21, 2012, 02:56:48 am
Hoble
  • 76
Re: Performance IDI 1.6/1.9 Hydraulic camshafts now in stock and ready to go!
« Reply #60 on: November 21, 2012, 02:56:48 am »
Huh. Down the centre of each lobe starting about half way to the point, there is a weld mark, it goes from the Grau of the cast to like a brass color weld ten back to cast.
Reply #61November 21, 2012, 05:22:34 am
« Reply #61 on: November 21, 2012, 05:22:34 am »
that is how they reground it. They take the base circle and ramp angles down to make it performance. I would guess that is just the machining, not weld.
Reply #62November 21, 2012, 05:27:03 am
« Reply #62 on: November 21, 2012, 05:27:03 am »
I never noticed anything different visually with the cams that I saw. Can you post pics?
Reply #63November 21, 2012, 06:28:23 pm
Hoble
  • 76
« Reply #63 on: November 21, 2012, 06:28:23 pm »
coming from a welder, that looks like a tig weld weaved back and forth then re ground off... didnt use the same metal as a filler ether
Reply #64November 22, 2012, 01:54:00 pm
Hoble
  • 76
« Reply #64 on: November 22, 2012, 01:54:00 pm »
That's not a machining mark at all.
Reply #65November 22, 2012, 06:43:18 pm
« Reply #65 on: November 22, 2012, 06:43:18 pm »
Not entirely machining mark, but I think you are correct it was welded then machined off. I would guess it was a fix of a flakey hydro cam. Those things seemed to always have some metal flakes coming off of them.
Reply #66November 22, 2012, 06:46:30 pm
Hoble
  • 76
« Reply #66 on: November 22, 2012, 06:46:30 pm »
Was told its a dr d cam but there's no proof. There is no way to tell eh?
Reply #67November 22, 2012, 06:50:22 pm
« Reply #67 on: November 22, 2012, 06:50:22 pm »
You could measure the base circle of it and a normal hydro cam and if the one is smaller that is probably the case.
Reply #68November 25, 2012, 05:55:43 pm
Hoble
  • 76
« Reply #68 on: November 25, 2012, 05:55:43 pm »
around the central axis the cam would rotate (the big lobe) was smaller and over all height from point to base was about the same, touch taller but nothing major. this was is comparison to a 1.9 idi cam i had laying around. sound right to be a dr. d cam?
Reply #69November 25, 2012, 06:22:26 pm
« Reply #69 on: November 25, 2012, 06:22:26 pm »
I would think so, not for sure, you could ask burn your money or Giles email. They should know for sure.
Reply #70November 25, 2012, 07:39:42 pm
« Reply #70 on: November 25, 2012, 07:39:42 pm »
I don't know. A smaller base circle is how regrinds are done. Without exact measurements I don't think there is anyway to know for sure who made this cam. I don't have the specs anymore so I'm of no real help.
Reply #71December 19, 2012, 09:33:50 am
Zaro
  • 33
« Reply #71 on: December 19, 2012, 09:33:50 am »
Your Dr. diesel cam was pulled from a built little 1.6NA mk2 golf. It was white with green interior if that rings a bell... Im 100% sure it was a dr. diesel cam. I'll find out who built the engine and you can talk to him yourself through Customobsessions.
I have another performance cam sitting here if youd like to compare. Although im not sure who did the regrind. Youd have to ask Chris Russell that question as it came from the race Rocco I bought and parted out.
Reply #72March 11, 2013, 01:43:38 pm
Jetmugg
  • 530
Are there any of these cams currently available for sale?
Steve.
Reply #73March 14, 2013, 06:20:31 am
RustyCaddy
  • 395
Steve.
i think Giles is/was selling them recently
Reply #74October 25, 2013, 04:26:03 pm
« Reply #74 on: October 25, 2013, 04:26:03 pm »
Any thoughts about using these cams in a 1Z/AHU TDI?  I've seen some folks talking about AAZ cams being a bit better than the TDI ones, if that's the case would these be better still?
