Author Topic: compound turbo setup on a 1.6td  (Read 5021 times)
May 11, 2010, 06:39:27 am
jimbobpolo
  • 45
« on: May 11, 2010, 06:39:27 am »
hey guys ive got this idea of a compund turbo setup that i want to put together,
just wanted opinions and advice really, ive got a 1.6td engine that im building up and i have a garrett t2 with choice of turbine housings and the original KKK k24 that came with the 1.6.
would there be a big enough size difference to warrant compounding the t2 with the k24?
i have the pipework to be able to make the setup work, just wondered if it would be worthwhile?
cheers
james  :D
« Last Edit: May 11, 2010, 12:16:09 pm by jimbobpolo »
Reply #1May 11, 2010, 08:45:25 am
Re: compound turbo setup on a 1.6td
« Reply #1 on: May 11, 2010, 08:45:25 am »
i, personally would go with a smaller high pressure turbo..
Reply #2May 11, 2010, 06:02:02 pm
colhel59
  • 34
« Reply #2 on: May 11, 2010, 06:02:02 pm »
i was also wondering if any one here has done one would like to see the set up
Reply #3May 11, 2010, 08:11:28 pm
rallydiesel
  • 1880
« Reply #3 on: May 11, 2010, 08:11:28 pm »
Hey I'm not too far from you. Anyways, I don't know if anyone has done up a 1.6td. Mark Malone (a mod) out of BC has built or helped build a compounded 1.9 tdi. Andy2 has built a compound idi I think although I don't know what the base engine was.
The Malone Tuning tdi makes around 450hp!!!!!!!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4May 12, 2010, 10:08:00 am
« Reply #4 on: May 12, 2010, 10:08:00 am »
andy2 has a jetta with a compound setup. ive seen a video of it before.. takes a FAT shot of ether to get it running.
Reply #5May 16, 2010, 09:03:25 pm
jpedro
  • 137
« Reply #5 on: May 16, 2010, 09:03:25 pm »
im also in the process of doing a compound setup as well, but would love to see everyones pictures if there available.
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe
1992 Ford F250 7.3L IDI custom everything you can possibly think of. ( my braging rights are live with this toy)
Reply #6May 16, 2010, 10:06:25 pm
mystery3
  • 774
« Reply #6 on: May 16, 2010, 10:06:25 pm »
I think a single properly sized twin-scroll modern ball bearing turbo would do much better than the t2 and the k24 in conjunction.
