Author Topic: new clutch cable... REVERSE LIGHTS ALWAYS ON?  (Read 5658 times)
May 07, 2010, 04:13:56 pm
ashleyroe
« on: May 07, 2010, 04:13:56 pm »
so we just put a new cable in.
was letting off alittle high, so we adjusted it.
didn't realize we were turning the wrong way.
went to drive off and i had nothing, so i reversed back into the drive way.
adjusted the cable correctly. took it around the block....
perfect. but, now the reverse lights won't go off.
any ideas?
Reply #1May 07, 2010, 05:56:13 pm
ashleyroe
Re: new clutch cable... REVERSE LIGHTS ALWAYS ON?
« Reply #1 on: May 07, 2010, 05:56:13 pm »
one of the inside nubs is sticking.
i need a new six pin switch but apparently they are super rare.
any one have one i can buy, pretty pwease?  :-[
Reply #2May 10, 2010, 08:58:25 pm
« Reply #2 on: May 10, 2010, 08:58:25 pm »
Is it possible to disassemble it? I know the four pin ones can come apart and get fixed.
Reply #3May 11, 2010, 06:25:51 am
ashleyroe
« Reply #3 on: May 11, 2010, 06:25:51 am »
no it doesnt come apart, the one broke gave me turned off the reverse lights but now they wont come on lol...
so i'm still looking.
Reply #4May 11, 2010, 01:40:51 pm
Baron VonZeppelin
« Reply #4 on: May 11, 2010, 01:40:51 pm »
The contacts under those little nubs that get pushed in when the tranny link engages them, get the most wear on the one that works reverse light.
Your old one was hung together on the contacts there.
BOTH of my 85 ACH tranny's multi-prong switches are just like the one you have now (as far as not working the lights). The reverse nub has a different feel to it when you take it out and work it by hand, as opposed to all the other nubs that seem perfect in operation.
You probably need to just go with the 5 pin. You can still get them new. OEM is about $90. I found aftermarket as low as $20'ish.
But I'm too cheap to buy yet. Going to pull 2-3 at junkyard tomorrow first, and check them out for a replacement in the Jetta.
In the Truck, i just wired a dash toggle that illuminates ($5) when its on, for the reverse lights. Thought it might come in handy to have the lights on-call when loading/unloading at night or hooking/unhooking a trailer. It's a man thang, probably not what you want in your Rabbit.
G/L on fix soon
« Last Edit: May 11, 2010, 01:42:31 pm by Baron VonZeppelin »
Reply #5May 11, 2010, 02:50:21 pm
« Reply #5 on: May 11, 2010, 02:50:21 pm »
Had such a switch on my first VW van on purpose... great for those guys who crowd your butt at traffic lights 'cause they think you've accidentally selected "Reverse" instead of "Drive" and are about to back into 'em when the light turns green.
Also had a switch on the brakelights... great for tailgaters on the freeway.
OK, sorry OP... back on topic....    ;-)
Reply #6May 11, 2010, 06:50:01 pm
Baron VonZeppelin
« Reply #6 on: May 11, 2010, 06:50:01 pm »
lmao
Reply #7May 11, 2010, 08:04:52 pm
fck
  • 70
« Reply #7 on: May 11, 2010, 08:04:52 pm »
i'd like to get some KC highlighters facing backwards on a roof rack to EXPLODE into HIGH BEAMS on the ol' tailgaters.  :P
Reply #8May 12, 2010, 10:27:48 pm
79rabbit4dr
« Reply #8 on: May 12, 2010, 10:27:48 pm »
:idea:
blinding lights + thick black smoke = ultimate tailgater eliminator.
Reply #9May 13, 2010, 09:01:30 pm
macka
  • 957
« Reply #9 on: May 13, 2010, 09:01:30 pm »
  I have a set of sodium lights for those special occaisions on my truck.
Quote from: Vincent Walden
Reply #10May 18, 2010, 07:26:33 am
ashleyroe
« Reply #10 on: May 18, 2010, 07:26:33 am »
well the switch broke had giving me doesnt work. the lighst didnt even turn on.
i bought a new 5 pins from moogie and it worked for a week, beautifully.
now they are stuck on again...
any ideas?
Reply #11May 18, 2010, 07:37:17 pm
Baron VonZeppelin
« Reply #11 on: May 18, 2010, 07:37:17 pm »
Make a warranty claim, and try again.
Spray as much lithium lube into the actuator nub sockets as will go in there before next launch.
if all else fails, there's always the toggle switch in one of the lower dash bezel blanks, as an option ... ....
Reply #12May 18, 2010, 07:43:00 pm
« Reply #12 on: May 18, 2010, 07:43:00 pm »
Maybe relaying the reverse lights will save the switches.
Reply #13May 19, 2010, 10:03:47 am
ashleyroe
« Reply #13 on: May 19, 2010, 10:03:47 am »
i'll try it.
Reply #14May 19, 2010, 10:47:52 am
« Reply #14 on: May 19, 2010, 10:47:52 am »
Search ebay for "1156 LED". I bought these,
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230466781626&viewitem=&sspagename=STRK%3AMEWNX%3AIT
but after installing them I wish I'd bought these,
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110429681108&viewitem=&sspagename=STRK%3AMEWAX%3AIT
The second ones I posted will shine forward and backwards thus using the cars reflector.
They draw so little amperage that you won't need to relay them.
