Author Topic: My 81 vw pu 1.6 na to td build  (Read 56126 times)
Reply #15May 10, 2010, 09:44:34 pm
81 vw pu
Re: My 81 vw pu 1.6 na to td build
« Reply #15 on: May 10, 2010, 09:44:34 pm »
Here a couple of pics of the new downpipe i had to build to clear the relay shaft. The downpipe that came with the kit was'nt even close. I also had to bend the top leg of the relay shaft down about an inch.
Reply #16May 25, 2010, 11:40:02 am
81 vw pu
« Reply #16 on: May 25, 2010, 11:40:02 am »
Well i have about 500 miles since i added the turbo, and I must say I have no regrets yet. Did the advance mod yesterday. I had to check 4 different pumps, to look for a green spring. The best i found was a red one so i used it with the 2 thinnest shims. Took her for a short drive and noticed quite an improvement in 1st and 2nd gear. The rpm's seem to climb higher and faster.
Reply #17May 25, 2010, 07:46:05 pm
ToddA1
  • 434
« Reply #17 on: May 25, 2010, 07:46:05 pm »
Well this boost my confidence in Prothe slightly.  Still not sure if I'd give him any of my money.  Glad it's up and running.
-Todd
Reply #18May 25, 2010, 08:58:59 pm
« Reply #18 on: May 25, 2010, 08:58:59 pm »
its a good cheap kit. The rule of "you get what you pay for" applies. However, with anything cheap there is still a great success rate ;) Congrats!
Reply #19July 01, 2010, 10:12:02 pm
81 vw pu
« Reply #19 on: July 01, 2010, 10:12:02 pm »
Well I have about 1500 miles since I added the turbo to the caddy, with only one minor problem. Had to tighten the fitting on the turbo for the oil supply line. I have tried several different valve cover breathers that vent crankcase vapors under the hood instead of running it back to the air intake, but sitting at a stoplight you can smell the vapors and I don't really care for that. Right now I have a hose from the block to a tee on the valve cover vent, and then down between the rack and pinion and firewall that's working good. No oil coming out on the ground or undercoating the truck. So far the prothe turbo kit has performed well for me and I would recommend it for anyone that can't find cheap stock td parts in their area as is the case around here. I have about $700.00 in the whole swap including all new studs and nuts. oil supply and return lines, air intake, hotpipe, and new straight-pipe exhaust. Also the stock 1.6na intake gasket hasn't failed (yet) on the D-port TDI intake, but I'm only seeing 10-11 lbs. boost max.  Thanks to everyone for all the great information on this site.
Reply #20July 02, 2010, 06:04:25 pm
punkvideo81
  • 168
« Reply #20 on: July 02, 2010, 06:04:25 pm »
Sounds like a cool build. Can you post some pics of your caddy? Or how about a video of a drive by? That would be sweet.   ;D
'81 Caddy 1.6 TD
Reply #21July 04, 2010, 12:23:09 pm
81 vw pu
« Reply #21 on: July 04, 2010, 12:23:09 pm »
 Here's a few pics of my 81 caddy punkvideo81.
Reply #22September 07, 2010, 12:34:13 pm
81 vw pu
« Reply #22 on: September 07, 2010, 12:34:13 pm »
Just installed a dry nitrous kit on the caddy!!!  ;D  Anyone else running nitrous on their vw diesel???
Reply #23October 05, 2010, 10:04:59 am
punkvideo81
  • 168
« Reply #23 on: October 05, 2010, 10:04:59 am »
this is getting even more interesting, how did it work?
'81 Caddy 1.6 TD
Reply #24October 05, 2010, 10:24:29 pm
Powered by Spearco
  • 1203
« Reply #24 on: October 05, 2010, 10:24:29 pm »
Tell us more about the NOS. Which kit, how much, where did you hide the bottle, how did you route it and what not?  :).
Nice looking truck.
Whats up with the Jeep  ::).
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #25October 06, 2010, 11:07:54 am
81 vw pu
« Reply #25 on: October 06, 2010, 11:07:54 am »
I love it, spools the turbo faster and drops egt's by about 200 degrees.
I sprayed a 10 lb. bottle in less than a day doing some tuning with a 25 shot jet.
Nice looking truck.
Its a dyno Tune universal efi kit 609.1 no bottle or brackets $179.00. The bottle is mounted in the bed on the ds front, but as soon as I can get a blowdown tube on the bottle its going back in the cab between the seats right below the back window. I ran the nos supply line down the ds along the brake lines and up by the master cylinder to the nos solenoid, and then over to the spray nozzle mounted in the intake. It has a arming switch that I put down by the emergency flasher button, and a micro switch I mounted on the injection pump so it only sprays at wot.
The jeep is a 1960 cj5 with a fuel injected 4.3, gm sm 420 4sp. dana 20. I built it about 10 years ago, but only gets driven 2-3 times a year now.
Reply #26October 07, 2010, 08:28:13 am
« Reply #26 on: October 07, 2010, 08:28:13 am »
i had nitrous.. it was a waste of time in my eyes.. its over 50 bucks for a 10# bottle..
and i had a whole bottle sprayed out in no time. but the turbo makes more power, by far.. i never had them paired together tho. never had the want to do it. i had it hooked up on an n/a with a header, and it would make a difference, but not like being turbo'd or non turbo'd..
Reply #27October 07, 2010, 09:58:22 am
81 vw pu
« Reply #27 on: October 07, 2010, 09:58:22 am »
I buy the big bottles of nos from a welding shop and refill my own bottles, so its less tham $3 a lb. I was very disappointed the first time I sprayed the caddy, I didn't have enough fuel to take full advantage of the nitrous. After turning up the fuel and getting better results I bumped the nitrous from a 024 to 028 jet and added even more fuel. Its nothing like a monster shot on a gasser, but remember its a 4 cyl. diesel!!!
Reply #28October 07, 2010, 12:57:21 pm
punkvideo81
  • 168
« Reply #28 on: October 07, 2010, 12:57:21 pm »
ok, time for a drive by video just as you hit the nitrous  ;D
'81 Caddy 1.6 TD
Reply #29June 05, 2011, 06:04:17 am
81 vw pu
« Reply #29 on: June 05, 2011, 06:04:17 am »
Here's a couple of crappy videos of my caddy at renegade raceway.
Time only run.
"http://www.facebook.com/v/232793063400923"
1st round red light!!!
"http://www.facebook.com/v/162250690455161"
