Author Topic: 1984 Jetta , TDI WE MUST! (1.9 AHU M-TDI)  (Read 332239 times)
Reply #195February 23, 2012, 05:41:07 am
Re: 1984 Jetta , TDI WE MUST!
« Reply #195 on: February 23, 2012, 05:41:07 am »
8V, don't ignore the bit I said about removing the cold start advance piston cover.  It will leave you stranded.
Reply #196February 23, 2012, 08:25:02 am
« Reply #196 on: February 23, 2012, 08:25:02 am »
Can I replace that back cover with the front cover off of another pump :) ?
Reply #197February 23, 2012, 09:31:34 am
« Reply #197 on: February 23, 2012, 09:31:34 am »
Yes, but better, IMO, is the flat steel plate from the AHU or similar engines.  Every time the engine returns to idle, the advance piston hits that plate.
Reply #198February 23, 2012, 09:34:36 am
« Reply #198 on: February 23, 2012, 09:34:36 am »
Perfect I should still have one on my ahu pump.
Reply #199February 24, 2012, 11:19:35 pm
Baron VonZeppelin
« Reply #199 on: February 24, 2012, 11:19:35 pm »
As things went along - i gained more knowledge and some factoids about these 1.9 TDI 1Z / AHU. Just to share in case it helps anyone.
The tensioner marks that i thought meant it was way over-tightened, actually were just the opposite. It was WAY too loose. During some pre-emptive testing - the Inj Pump jumped 3 cogs on the belt - when i was cheating by turning engine some with Inj Pump bolt.
I've used the cheat many times before - but never jumped the belt.
So thats when the pre-emptive tests stopped and i got more involved with the tensioner / belt specs. lol
To refresh - this is where the existing tensioner was set.
This is where the tensioner should set initially - with cam sprocket loose.
This is where it moves to, after cam bolt is torqued.
This where it settles to, after about 20 revolutions.
And this is the tension spec - after about 20 revolutions - with the idler/roller removed from belt path. Practically a perfect 13 units.
For reference - 1.6 spec is 12-13 units.
Luckily for this 116k pristine low miler , this condition was caught.
New Belt, Tensioner, and Roller for a fresh new start.
And an intermediate shaft seal too.
8V have you checked your tensioner setting yet ??
« Last Edit: February 24, 2012, 11:23:41 pm by Baron VonZeppelin »
Reply #200February 26, 2012, 05:26:17 pm
« Reply #200 on: February 26, 2012, 05:26:17 pm »
Swear to god, I have magic fingers. (it is what she said) This was the first attempt from when I did the swap.. took the picture tonight. With out knowing at all, I had the belt tension dead on. ;)
Reply #201February 26, 2012, 06:56:05 pm
« Reply #201 on: February 26, 2012, 06:56:05 pm »
mmmmmm gasser motor mount... i HOPE you put a shim behind the front 2 bolt holes... the step in the mount is for the alt/ac bracket... and no shim it will BREAK those bolts/block..
Reply #202February 26, 2012, 07:00:56 pm
« Reply #202 on: February 26, 2012, 07:00:56 pm »
Yessir, it allowed me to use the AHU pump mount for my IP.
No sir I did not use shims, It had no shims on my original mk1 gas motor.. why do I need them now?
Fwiw, that step in the mount was stock to ALL gas mk1 mounts AC or not. No shims were on my mount when I removed it from the stock gas motor.
« Last Edit: February 26, 2012, 08:09:58 pm by 8v-of-fury »
Reply #203February 26, 2012, 09:12:25 pm
« Reply #203 on: February 26, 2012, 09:12:25 pm »
ac or alt bracket is behind that to be a shim... trust me on this... you need to do something.. it will vibrate and BREAK the mount, bolts or block.. you need to fill that gap...
Reply #204February 26, 2012, 09:37:01 pm
« Reply #204 on: February 26, 2012, 09:37:01 pm »
You know, you might be on to something here. ;D Would it hurt to write in proper sentences? lol Whenever I read your posts, I think of somebody who has just run a couple of blocks and is out of breathe. Then they try and tell their story, and it has pauses after every three or four words. lol
Reply #205February 27, 2012, 12:49:38 am
« Reply #205 on: February 27, 2012, 12:49:38 am »
makes it hard to read when all the words are too close together...
ive seen what happens when the ac unit on a mk1 gassers start to pop bolt heads.. why i asked on the shim... :D it needs/requires something there to prevent the mount from flexing.. gotta be solid.. else that bolt head will pop off and fall into the timming belt..
Reply #206February 27, 2012, 08:14:18 am
« Reply #206 on: February 27, 2012, 08:14:18 am »
but it flooowwwsss lol
Sir, yes sir. I will look in to this today, as I will have the belt and pump off anyhow :).
Reply #207February 27, 2012, 01:13:14 pm
Baron VonZeppelin
« Reply #207 on: February 27, 2012, 01:13:14 pm »
You were damm close on the tensioner setting.
I'd have been happy to find it like that - if not knowing beforehand.
Probably within the 12 unit zone.
Since you're having it loose again - this time go for full spec.
Marker should move south of the notch a little bit, after cam bolt torque.
Reply #208February 27, 2012, 01:25:42 pm
« Reply #208 on: February 27, 2012, 01:25:42 pm »
Will do. :)
Reply #209February 27, 2012, 02:48:15 pm
« Reply #209 on: February 27, 2012, 02:48:15 pm »
Andrew, I just realized with my pump on the bench that removing the cold start advance mechanism will affect how much idle adjustment there is with the little spring inside of the pump.. I will have to crack the lid of again and remove that little spring won't  i..
