Author Topic: Almost together!  (Read 1873 times)
April 26, 2010, 09:47:03 pm
ffgb
  • 244
Almost together!
« on: April 26, 2010, 09:47:03 pm »
I finally dropped in my motor/transmission minus cylinder head.  Slowly installing things on the block because I don't want to scratch the detroit diesel alpine green painted block.  I do have a question, while installing the rotary vacuum pump, I installed an o-ring under the base where it contacts the engine block, but it seems that the o-ring isn't so think.  Can this be right?  Also, I installed the Sabo rear main seal with a cutoff 2-liter bottle, I hope the spring didn't dislodge, because if it did, there goes my Exedy light weight clutch/flywheel combo!  I will have pics as soon as I get the head on and bolt the intake/exhaust manifolds.  This build has taken an eternity!
