Author Topic: 1.6N/A Crankshaft bolt  (Read 10196 times)
Reply #15April 25, 2010, 09:23:12 pm
ffgb
  • 244
Re: 1.6N/A Crankshaft bolt
« Reply #15 on: April 25, 2010, 09:23:12 pm »
Well, I still have the new one coming in on tuesday.  The computer at the dealership said "hexhead", but does that mean I get the hexhead bolt or the 12 point bolt?  Is it possible to use the old one to set everything up, like the timing belt and pump timing, then take off the old bolt and install the new one when it comes in, or will the timing gear sprocket wobble under pressure without a bolt there?
Reply #16April 26, 2010, 12:04:29 am
Rabbit79
  • 197
    Burns, Oregon,USA
« Reply #16 on: April 26, 2010, 12:04:29 am »
I have no idea on that one. Usually whenever I've ordered parts if a part has been superceded by a new one the computer will show it and direct you to the new part. Guess you'll just have to wait and see.
As for using the old bolt for set-up purposes........if it were me I'd prefer to wait until I had everything in it's final configuration and torqued down properly. That's just me though. It's only 2 extra days until you get the new bolt.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #17April 26, 2010, 09:56:07 am
  • 2932
« Reply #17 on: April 26, 2010, 09:56:07 am »
A hex head bolt with a shoulder,
 like the one you posted a picture of,
 is a 1 time used TTY bolt.
 Hex without the shoulder is reusable. Probably no longer available because they went to the shouldered TTY.
 I reuse the non-shouldered ones.
 If anyone ends up using the new 12-point bolt,
 get a 3/4" breaker bar and extension.
 I twisted my 1/2" drive extension trying to give the bolt another 1/2 turn.
 Crazy high torque.
Reply #18April 27, 2010, 10:03:23 am
Rabbit79
  • 197
    Burns, Oregon,USA
« Reply #18 on: April 27, 2010, 10:03:23 am »
For the benefit of an old geezer who is not savvy in internet speak.......What does TTY stand for? (Yes I checked the page that defines abbreviations....this one wasn't on there)
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #19April 27, 2010, 10:27:27 am
« Reply #19 on: April 27, 2010, 10:27:27 am »
Torque To Yield ;D
Reply #20April 27, 2010, 12:14:30 pm
« Reply #20 on: April 27, 2010, 12:14:30 pm »
I have my crank bolt sitting on the desk in front of me as I write this. My motor is also an 84 with a JK engine code. The only difference I see is the washer and the top of the bolt. The top of my bolt is not recessed, just flat across the top, so no significant difference there. The washer on mine is stepped down to a smaller size though, so it's way different. My crank gear is the type that's held in place by a woodruff key. I understand there are differences on the type of gear that pulls the timing belt? so check that.
i believe the woodruff key only came on very early engines. a couple of my 1.5's have the woodruff key too. im not sure if its 1.5 specific tho.
« Last Edit: April 27, 2010, 12:17:12 pm by Rabbit on Roids »
Reply #21April 27, 2010, 12:39:45 pm
truckinwagen
  • 1895
« Reply #21 on: April 27, 2010, 12:39:45 pm »
1.5 and early 1.6
83 Opel Kadett Diesel
Reply #22April 29, 2010, 05:09:50 pm
ffgb
  • 244
« Reply #22 on: April 29, 2010, 05:09:50 pm »
Well, the new bolt is a six point hex with shoulder or as the reps at the dealership say, a built in washer.  So what is the torque setting on this.  In the Bentley, I am reading 148ft lbs lubricated.  If this is a TTY bolt, it doesn't say anywhere for an additional 1/4 or 1/2 turn.  So I am guessing just torque to 148ft lbs and call it good?  What is the best lubricate to use, motor oil, loctite, or ARP moly grease?
Thanks
Reply #23April 29, 2010, 08:15:59 pm
  • 2932
« Reply #23 on: April 29, 2010, 08:15:59 pm »
How does the bolt compare in length,
 to the old one?
Andrew I think my last bolt was 12 point, you use a 6-point socket??
 Was wondering if you've used one of the 12-point crank bolts?
ffgb, I might have missed it, what is your block code?
Reply #24April 29, 2010, 09:16:47 pm
ffgb
  • 244
« Reply #24 on: April 29, 2010, 09:16:47 pm »
Same length bolt.  My engine code is JK. Stock bolt is hex head with shoulder, just like new one, according to the dealership.  I spoke to the parts technician over the phone, because I won't be able to pick up the bolt till saturday.  He said it was 6-point.  I guess the only way to know for sure is to pick it up on saturday.
Reply #25April 30, 2010, 10:37:35 am
  • 2932
« Reply #25 on: April 30, 2010, 10:37:35 am »
That 12point bolt is shorter,.. had me confused for awhile,.. until I realised it gets used without the washer.
