Author Topic: Alternator sepentine belt tool ?  (Read 2088 times)
April 17, 2010, 07:42:11 am
GEE-BEE
  • 1604
« on: April 17, 2010, 07:42:11 am »
Is there a special part that you are using ?
Iam keeping a extra belt under my seat.
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1April 17, 2010, 08:00:53 am
GEE-BEE
  • 1604
Re: Alternator sepentine belt tool ? ( 1.9 AAZ )
« Reply #1 on: April 17, 2010, 08:00:53 am »
I just installed a new Bosch 120 amp with the clutch pulley, not alot of room in a MK1 caddy
You have to remove the entire alt bracket since the thru bolts ( mounts for alt)are close to the body.
I purchased some M8 x 90 mm s/s bolts to fight the corrosion.
I have a lift and ran the belt around the lower , asked for some help on holding the arm up while routing the belt around the pulley.
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #2April 17, 2010, 09:40:52 am
GEE-BEE
  • 1604
« Reply #2 on: April 17, 2010, 09:40:52 am »
nice work...
Do you know the tool # or Mfg'
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3April 26, 2010, 10:34:09 pm
Quantum TD
  • 1195
« Reply #3 on: April 26, 2010, 10:34:09 pm »
Vice grips work like tits.
Reply #4April 27, 2010, 06:01:29 pm
GEE-BEE
  • 1604
« Reply #4 on: April 27, 2010, 06:01:29 pm »
If  I remove my air filter assy it was much easier to get at ( MK1 , the right size monkey wrench is working...
Thanx to all...
GB
Giles Pump OHC
MK1 JETTA DASH
