Boost K24
Topic: Boost K24 (Read 2145 times)
April 15, 2010, 03:11:02 pm
dennis
Boost K24
April 15, 2010, 03:11:02 pm »
20 psi too much??? 25?
? Boost pin is set at max. star wheel is about three turns from the bottom. Flat road 80 mph 850-950 EGT holding about 8 psi boost pressure. Almost 200 kilomiles on the engine.
Last Edit: April 15, 2010, 03:15:10 pm by dennis
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
April 15, 2010, 03:21:21 pm
rallydiesel
Re: Boost K24
April 15, 2010, 03:21:21 pm »
I think it will take some mods to get 25 psi out a k24 while keeping the egt's reasonable. I max out at 17 psi at around 1400F with a straight exhaust but stock diameter and no intercooler. I have head studs/metal hg too but they are really not a factor below 25 psi.
1991 Jetta TD - sold
2001 Golf TDI - Son's
April 15, 2010, 03:40:17 pm
dennis
Re: Boost K24
April 15, 2010, 03:40:17 pm »
Iv got 2.25" exhaust, and a small intercooler plus its a Caddy. Not very heavy. Yeah the EGT is really climbing at 20 psi but I usually back off at about 1200 degrees. I have a long comute so my driving is mostly highway.
April 15, 2010, 04:49:42 pm
TDsamurai
Re: Boost K24
April 15, 2010, 04:49:42 pm »
is the only limitation to boost out of a k24 the EGT's? i was told that 20psi for short periods of time is ok but for too long it will kill it. I wasn't told what the limiting factor was. Thanks
Boost K24
