Author Topic: Anyone seen this before? (IP rebuild content)  (Read 2194 times)
April 09, 2010, 10:46:03 pm
sawedoffgolf
  • 213
« on: April 09, 2010, 10:46:03 pm »
I've begun rebuilding my ip and inside the 4 pressure valves they have a spring, well 3 of the 4 springs have a little end broken off. Anyone seen that before? anyone have some spares they want to get rid of? ;D
Reply #1April 11, 2010, 04:26:02 pm
sawedoffgolf
  • 213
Re: Anyone seen this before? (IP rebuild content)
« Reply #1 on: April 11, 2010, 04:26:02 pm »
Reply #2April 11, 2010, 04:43:46 pm
410
  • 581
« Reply #2 on: April 11, 2010, 04:43:46 pm »
I've never seen that before.  What kind of pump are you working on?  1.6td?  1.9td?  I might have some extras for you if you can't find any in your area.
Reply #3April 11, 2010, 06:47:30 pm
« Reply #3 on: April 11, 2010, 06:47:30 pm »
How was it running?
It's fairly rare from what I have seen. It's very rare for 3 of them to fail ???
Reply #4April 11, 2010, 09:25:15 pm
sawedoffgolf
  • 213
« Reply #4 on: April 11, 2010, 09:25:15 pm »
the pump that failed on my car is still on there and i dont know how those springs are, this is a spare pump which i received from a friend, the car ran like *** basically, the ip dripped puddles, the engine had low compression and about to die so its hard to say if the ip caused some of the rough running. I plan to rebuild this one while its off and then switch them and rebuild the other one.
The spring in the picture below was also missing, it was taken from the 2010 governor mod thread.
