Author Topic: Gauges  (Read 6473 times)
April 04, 2010, 05:47:54 pm
stewardc
Gauges
« on: April 04, 2010, 05:47:54 pm »
Does anyone make a full-sweep electronic gauge line that looks close to the OEM VDO gauges in a Rabbit?
Reply #1April 04, 2010, 08:42:24 pm
Re: Gauges
« Reply #1 on: April 04, 2010, 08:42:24 pm »
What size?
Reply #2April 05, 2010, 02:24:51 am
stewardc
Re: Gauges
« Reply #2 on: April 05, 2010, 02:24:51 am »
Same as OEM VDO.
Reply #3April 05, 2010, 11:20:10 am
blackdogvan
  • 574
Re: Gauges
« Reply #3 on: April 05, 2010, 11:20:10 am »
Not VDO but autometer finally is making full sweep electronic. Not cheap either.
http://www.jegs.com/p/Auto-Meter/Auto-Meter-Competition-Series-Gauges/1151149/10002/-1
1991 Vanagon 1.9 mTDI
Reply #4April 05, 2010, 07:46:21 pm
GEE-BEE
  • 1604
Re: Gauges
« Reply #4 on: April 05, 2010, 07:46:21 pm »
Get the mcnally with the dual Type:
boost/ EGT temp
Oil psi/ oil temp
Volt/water
Want a pic of all three of mine in my gti console ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5April 06, 2010, 02:47:05 am
  • 3468
    • McScrubbins Body Wash
Re: Gauges
« Reply #5 on: April 06, 2010, 02:47:05 am »
what kinda coin did you pay for that GEEBEE?
Reply #6April 06, 2010, 03:42:22 am
stewardc
Re: Gauges
« Reply #6 on: April 06, 2010, 03:42:22 am »
Yes, indeed, though a dual gauge is normally harder to read than a full-sweep gauge.
boost/ EGT temp
Oil psi/ oil temp
Volt/water
GB
Reply #7April 06, 2010, 06:10:34 am
GEE-BEE
  • 1604
Re: Gauges
« Reply #7 on: April 06, 2010, 06:10:34 am »
MCNALLY, there new product will be avail in different color's
around 708.00 for the setof three
MCNALLYELECTRONICS.COM
I started with the boost / egt because I spent coin ( 915.00) on a hybrid turbo and I didnt want to burn it up..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #8April 09, 2010, 03:18:14 pm
Re: Gauges
« Reply #8 on: April 09, 2010, 03:18:14 pm »
i just bought Autometer Ultra lite II
Boost to 35psi and EGT gauge.
Steering column mounted..
