Author Topic: refilling gearbox oil in a 1999 1.9td transporter  (Read 3436 times)
November 24, 2005, 05:26:25 am
apriliaandy
« on: November 24, 2005, 05:26:25 am »
Simple stuff folks, but there are an assortment of nuts around the gearbox and I wanted to make sure which was which.  I was under the impression that the drain plug was a 17/19mm hex but the VW garage said not.  Also where is the fill hole....3ltrs correct?
Regards
Reply #1November 24, 2005, 06:37:03 am
Maarten
  • 339
« Reply #1 on: November 24, 2005, 06:37:03 am »
The plug is a 17mm hex (you can use a wheelbolt to unscrew it)
Fill it up till there is olie dripping out of the hole, I think 3 liter is too much.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2November 26, 2005, 04:18:29 am
apriliaandy
Thanks for that
« Reply #2 on: November 26, 2005, 04:18:29 am »
appreciated.
