Fixmyvw.com
Author Topic: 6.2l starving for fuel  (Read 2910 times)
April 04, 2010, 05:37:34 am
« on: April 04, 2010, 05:37:34 am »
This is a pretty now thing, if I'm under about 1/8 tank indicated, and I rally to hard in the turns, I suck air, and sometimes stall.  Esp. going uphill.
84 Suburban, completely stock fuel system.
I have never  run out of fuel, and have previously driven to 0 on the gauge without noticing anything like this.
It is possible my gauge is changing for the worse.
Maybe something in the tank is dissolving?
Anyone run across this before?
Reply #1April 04, 2010, 07:37:36 am
maxfax
  • 2126
Re: 6.2l starving for fuel
« Reply #1 on: April 04, 2010, 07:37:36 am »
IIRC the pickup int he tank is just a steel tube with a sock on the bottom..   My guess would be the gauge is starting to get funky...
GM gas gauges work bass ackwards from most....  The more resistance to ground though the sending unit gives a higher reading on the gauge..  For instance, if you unplug the sender in the the tank, the gauge will peg at full..  It is possible that you just have a crusty ground causing a higher than usual gauge reading...
« Last Edit: April 04, 2010, 07:03:16 pm by maxfax »
Reply #2April 04, 2010, 06:50:12 pm
« Reply #2 on: April 04, 2010, 06:50:12 pm »
Mmm, it has been wet a lot lately.
I think I have another cluster I can borrow a gauge from, sounds like the easy place to start.
Reply #3April 04, 2010, 07:06:02 pm
maxfax
  • 2126
« Reply #3 on: April 04, 2010, 07:06:02 pm »
Corrected that last post..   The MORE resistance to ground yields a higher reading..
Reply #4April 05, 2010, 11:00:20 am
« Reply #4 on: April 05, 2010, 11:00:20 am »
probably not the cluster, i bet its something to do with the sender or the ground to the sender.
Reply #5April 05, 2010, 02:06:16 pm
maxfax
  • 2126
« Reply #5 on: April 05, 2010, 02:06:16 pm »
That would be my guess as well..  I can;t remember off hand if they had a separate ground wire for the sender, or if it just grounded though the tank and such...   I know most of my old Fords just grounded though the tank.. Nightmarish for functioning gas gauges till I ran a separate grounds..
Reply #6April 05, 2010, 03:02:41 pm
« Reply #6 on: April 05, 2010, 03:02:41 pm »
not sure about that particular chevy, but i know the 90's style gas chevys have a separate ground from the sender to the top of the tank where all the connections are. i would just run the sender its own ground like brett was saying. the fuel pump has its own ground, but the gauge is supposed to ground through a rubber isolated tank? great plan!
Reply #7April 05, 2010, 05:11:52 pm
maxfax
  • 2126
« Reply #7 on: April 05, 2010, 05:11:52 pm »
Yes, when they went to having an in tank pump there was a little ground for the gauge..   Took a look at the diagram in Alldata and it appears that the earlier Chevy Trucks do have a ground to the frame from the sending unit...
Fixmyvw.com
