Author Topic: Crankshaft endplay  (Read 2796 times)
April 02, 2010, 09:09:51 am
ffgb
  • 244
Crankshaft endplay
« on: April 02, 2010, 09:09:51 am »
Can I just put new 6-piece 3rd main bearing and thrust washers in as they come in my engine.  The old ones were taken out from the machinist and gone.  He insisted on using the 2-piece but I didn't want to.  So do I just pop them in, or is there a procedure for the thrust bearing.  I cannot find any information in the bentley.  I guess it is better to pop in the new 6-piece ones without measuring rather than use the 2-piece ones without measuring?
Reply #1April 02, 2010, 06:28:07 pm
sdwarf36
  • 159
Re: Crankshaft endplay
« Reply #1 on: April 02, 2010, 06:28:07 pm »
You always want to check. Best way:with a dial indicator set on the end of the crank-stick a screwdriver between a couple of counterweights and check fore+aft motion. Next best: push the crank back-check with a feeler gauge between the front of the bearing+ crank thrust surface. In a pinch: just do the screwdriver trick-but have your finger touching the block and crank at the saem time and feel that there is SOME play. I don;t have the spec in front of me-but a guess would be .002-.005.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #2April 02, 2010, 07:13:39 pm
« Reply #2 on: April 02, 2010, 07:13:39 pm »
Tell us what car/engine you're referring to and we'll look it up for ya.   ;)
Reply #3April 02, 2010, 11:22:19 pm
ffgb
  • 244
« Reply #3 on: April 02, 2010, 11:22:19 pm »
my engine is a 1984 1.6NA from the rabbit with 4-speed.
the machinist did give back the thrust washers, they were in a box with everything else, i just don't know if there were the top/bottom/left or right side.  i didn't want to chance it, so i went ahead and bought new bearings with the 6-piece thrust washers.
i have a dial indicator for setting my timing, would that work?  I don't have the base to attach the gauge, where would i get one, harbor freight?  I can do the feeler gauge method, do i check with the crank pushed forward and back?
Reply #4April 03, 2010, 07:47:32 am
sdwarf36
  • 159
« Reply #4 on: April 03, 2010, 07:47:32 am »
Yup--thats all-slide the crank forward+back-the feeler gauge will tell how much. Measureing either direction is ok. Crank end play is far more critical on an automatic trans car than a stick.
