Author Topic: Turn Signal/ Hazard Issues...  (Read 9365 times)
Reply #15April 22, 2010, 12:07:11 pm
Rabbit79
  • 196
    Burns, Oregon,USA
Re: Turn Signal/ Hazard Issues...
« Reply #15 on: April 22, 2010, 12:07:11 pm »
I've been looking at my wiring schematic. Unfortunately my book only goes up to 84 so this may not help you but alot of times systems like this don't change much over the years so I might get lucky. It appears that power for the turn signals actually runs through the emergency flasher switch. From the fuse box off terminal 15, through fuse S19, then into the emergency flasher switch through contact 15 and back out the switch through contact 49 and from there back to the relay. It appears that if you pull the plug off the switch and jumper across 15 and 49 (of the plug, not the switch), you should get your turn signals to work, and that will mean the switch is the culprit. I have a hard time believing that the flasher relay is the problem, because from what I see here niether the 4-ways nor the turn signals would work if it was bad. I don't know what to say about the light on the dash, because from what I see on this schematic it shouldn't even work at all when you activate the turn signals  hehe. I wouldn't totally rule out the relay, but at least you can check this without spending any money. Remember though this is info from an 84 schematic so it may be totally useless, but I thought I'd give it shot.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #16April 22, 2010, 02:31:52 pm
  • 3468
    • McScrubbins Body Wash
« Reply #16 on: April 22, 2010, 02:31:52 pm »
okay im trying to understand what you mean here
So... pull the plug out of the switch (that i just replaced and is brand new) on the steering wheel...
and then jump locations 15 and 49? are they labelled? Can you draw a crude mspaint drawing and post it? I'd be ever so grateful.
Or do you mean ... locations on the fuse box where relays should go?
im not entirely sure what you're talking about.
Reply #17April 22, 2010, 09:49:21 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #17 on: April 22, 2010, 09:49:21 pm »
I mean the emergency flasher switch for the 4 ways.....I was understanding you'd replaced the turn signal switch, correct? Basically all you're doing when you do this is eliminating the emergency flasher switch from the circuit. If you're turn signals work when you do this then the emergency flasher switch is your problem. If not then you know to look somewhere else. The numbers could be on the switch or the plug or both, I've seen them both ways. If there aren't any numbers the book shows black/blue wire to number 15 and white wire from number 49. I should be able to scan the page and send it to you. If your e-mail address is on your profile page I'll get right on that. If it isn't my address is on mine so send me an e-mail and then I'll get it right to you.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #18April 23, 2010, 03:07:02 am
  • 3468
« Reply #18 on: April 23, 2010, 03:07:02 am »
Fantastic!
I noticed that with the hazards going with the key off the turn signal light in the dash does not come on.
with the key on "on" or "acc" then the light in the dash does flash and there is no dim glow between flashing.
Reply #19April 23, 2010, 10:43:26 am
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #19 on: April 23, 2010, 10:43:26 am »
If you can get your hands on another emergency flasher switch, perhaps out of a friend's car or something like that, and swap it out that would be the easiest way to check it. If not I don't think they're too scary expensive if you want to buy one. If that doesn't fix it, it sounds like you might have to start digging into the wiring. If you get to that point I'd suggest getting yourself a multi-meter and a book for your car. I'm hesitant to give you info out of my book since it doesn't cover your model year, and it won't be 100% accurate and could end up steering you in the wrong direction. Anyway though let's hope a flasher switch fixes it.
            1984 F-250
            1999 Ford Ranger
84 Rabbit
70 Bug
Reply #20April 23, 2010, 12:56:33 pm
  • 3468
« Reply #20 on: April 23, 2010, 12:56:33 pm »
Yes me too. I had the whole dash apart (just changed heater cores) and all the wiring still looks fresh & brand new.
I looked on the plug for the hazard switch and couldn't find any double digit numbers on it. But i was sort of busy jamming that heater box back in there.
speaking of which, if anyone is having windshield fogging issues and the air flow out of the vents on the top of the dash sucks try taking the dash out (with your deck and all the buttons rear window defog and stuff) the vent that goes up there can sometimes get really mashed up.
I had to rip mine apart and rebuild it with duct tape.
Reply #21April 25, 2010, 06:15:56 am
somolovitch3
  • 290
« Reply #21 on: April 25, 2010, 06:15:56 am »
Eddy, don't you have a post on this issue some place on this forum? Or is this the POST to reply to?
Did you find your meter? And did you fix the issue with both filiment lighty up on the front corner? Usually its inside the socket that the ground goes bad in cases like this, not the ground to boddy. Wuld not hurt to chec your body grounds at the front for grins. (That came out .....ok....?)
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #22April 25, 2010, 02:08:17 pm
  • 3468
« Reply #22 on: April 25, 2010, 02:08:17 pm »
i have one thread thats newer than this one called general electrical problems because i have this turn signal problem plus my high beams dont work, plus my day time runnings lights don't work plus my oil light/sensor sometimes come on.
but i sort of came to realize they are all separate problems that just happened to happen all in the same week. That thread can be removed.
The headlight switch is broken = running and highs
The main bearings and IM bearings were never changed = low oil pressure
and the turn signals i haven't figured out yet.
The both filliments coming on was due to a faulty bulb. Replaced the bulb and that went away.
I've replaced the switch on the steering wheel, the X-relay and the flasher relay, and the bulbs and none of which have fixed the problem.
I've spent several hours and over $50 on this so far....
I took the whole dash off to look at the wiring and it all looks fine! The bulb holders don't have any corrosion on them what so ever.
the tail lights aren't wet or have moisture in them and when i pull the bulb holders out you can tell they are getting old but they don't look damaged or anything.
the problem is somewhere between the switch on the wheel and the flasher relay...
my next test is to get my friend's gauge cluster and plug it into my car to see if that fixes it.
If my gauge cluster is hooped im probably going to make my own dash out of a sheet of aluminum because new clusters dont exist and used ones are like $75 and up.  For that price i may as well make my own drag style one just for fun.
« Last Edit: April 25, 2010, 02:10:35 pm by Smokey Eddy »
Reply #23April 26, 2010, 04:51:58 am
somolovitch3
  • 290
« Reply #23 on: April 26, 2010, 04:51:58 am »
I am not sure on the MK2, but the early MK1 had plug in wireing harneses for different parts of the car. Front , engine, mid, rear. There were five of them. Of course if the headlights work, the possability of the loom being unpluged is kind of low. Have you checked for voltage at the swich connection to see if is getting that far?
Good luck and keep us posted.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #24April 26, 2010, 09:12:19 am
  • 3468
« Reply #24 on: April 26, 2010, 09:12:19 am »
Well the switch does "do" something. It makes the light in the dash come on solidly so i know the switch is doing something. The switch also turns on the highbeams, which on my car actually turns the lights off completely.
I need to replace the headlight switch which i know for sure is broken because my dash lights are on all the time and my highbeams don't work.
I'm just at work right now so when i get home i'll start digging again. Sigh.
I still need to try jumping those points on the fuse box. Been a busy weekend.
Reply #25April 28, 2010, 05:40:08 pm
somolovitch3
  • 290
« Reply #25 on: April 28, 2010, 05:40:08 pm »
I have reread your posts, and have a question. Do your parking lamps work normaly? Key off, headlamp switch in the 1st position? Just the small element lighting?
A thought, try applying 12v to the left/right turn signal ( blk/wht-blk/grn) wires just to see if that part of the wiring works.
Really dumb and I know you checked, the 10 anp fuse for the tuns is good? :o
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #26April 29, 2010, 01:13:45 am
  • 3468
« Reply #26 on: April 29, 2010, 01:13:45 am »
Have work tomorrow. I'll do my best to remember this post when i get home.
I will make a list of all the tests in this whole thread and do a check list. then report back.
Thanks so much for the time and thought.
