S-PAutomotive.com
Author Topic: AWESOME Braking Power with new Set up  (Read 2853 times)
March 30, 2010, 07:51:46 pm
Doakster
  • 291
« on: March 30, 2010, 07:51:46 pm »
A while back i had upgraded my front brakes to a MK4 VR6/1.8T set up (11inch rotors, different spindles and MK4 VR6/1.8T calipers)
I also ending up installing completely new rear brakes including brake cylinders, new drums and new shoes a while later. Also flushed the entire system with new fluid.
The set up never really had the stopping power i thought it would.
So I decided to bite the bullet and get a new master cylinder, cleaned out a ridiculous amount of crap in the reservoir when i swapped it, and did another system flush.
And finally tonight, I installed a new set of EBC Red Series pads.
After I found a vacuum line unplugged from me doing some past motor work, all I can say is WOW!!
These brake are unbelievable, basically the entire system is new, and the EBC pads are incredible.
I only have to push the peddle half the way down and they'll start locking up....real big difference and i'd recommend this set up to anyone.
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #1March 31, 2010, 07:56:03 pm
GEE-BEE
  • 1604
Re: AWESOME Braking Power with new Set up
« Reply #1 on: March 31, 2010, 07:56:03 pm »
I did the same , huge G60 brakes and rotors, new master with MkII pedal swap and all new custom S/S brake hardlines and Goodrich s/s flex lines.
I mounted new 16V prop valves to the master cylinder before the new hardline was made to fit
My cheese on my pizza gets jet-lag to one side when I stop !
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2March 31, 2010, 08:08:19 pm
Doakster
  • 291
« Reply #2 on: March 31, 2010, 08:08:19 pm »
GB
The G60 calipers bolt right up to the orginal spindles right?
Reply #3April 01, 2010, 12:33:24 pm
GEE-BEE
  • 1604
« Reply #3 on: April 01, 2010, 12:33:24 pm »
WITH [email protected] ADAPTERS, HE ALSO MAKES REAR E-BRAKE CABLES FOR THIS APPLICATION
I DID 100 MM INNERS AND 90 MM OUTERS ON MY INSTALL ( CV AXLES )
Custom 020 3.67 with .71 ff  final fifth with peloquin LSD
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #4April 01, 2010, 10:21:24 pm
mystery3
  • 774
« Reply #4 on: April 01, 2010, 10:21:24 pm »
GB
Did you pull these out of the yard? I'm wondering what I should pull in terms of brake parts next time I find a g60 at the junkyard, already have the VC and intake manifold. Do you need the hubs etc. or is it just the calipers that are necessary with the adapters?
Reply #5April 02, 2010, 12:17:59 pm
GEE-BEE
  • 1604
« Reply #5 on: April 02, 2010, 12:17:59 pm »
I GOT THE SEATS AND THE ROTORS WITH CALIPERS FOR 400.00
SENT CALIPERS FOR REBUILD AND PAINT
SEATS WENT FOR A COMPLETE COVER WITH BLACK/WHITE NEW SCIROCCO MKII MATERIAL 650.00 PAIR
USED JMAN1066 ADAPTERS AND EBRAKE CABLES
HAD TO DO THE PEDAL SWAP , REMOVE THE STOCK PROP VALVES (  FRAME ) INSTALLED THE 16V PROP AT THE MASTER CYLINDER
ALL S/S HARDLINES AND FLEX , DONE....
EVERYTHING JUST BOLTED UP...
I spent hours preping my axle and springs for powder coating
Giles Pump OHC
MK1 JETTA DASH
Reply #6April 16, 2010, 03:12:15 pm
« Reply #6 on: April 16, 2010, 03:12:15 pm »
Good brakes are absolutely fun huh??
I remember the day I went from stock mk2 brakes to 11.3" rotors and dual piston calipers front and 8" (or something) Passat disc rears along with a larger master cyl.
It was fun!!
We all like to go fast but WAY to often we neglect the stopping part.
Go fast stop fast..
