Author Topic: multiple injection pumps identification help  (Read 8900 times)
March 29, 2010, 07:38:03 am
fuslit
  • 118
« on: March 29, 2010, 07:38:03 am »
I'm going through my garage cleaning out parts/restarting work on my turbo diesel project... I've got some pumps I need help identifying what engines they came off of,
I did search but i've only been able to id a couple based on the bosch part # using this link http://www.vepump.cn/CZB.htm
Here are the #'s
Pump #1
460 494 200
R 254 BS 4010
068 130 110N
015 949 83392
Pump # 2
couldn't read all the numbers, ends with 34 200 (or 94 200, i'll have to double check this.)
R 254 BS 4010
015 949 83124
Pump # 3
NR 0 460 494 210
R 270 BS 4017
068 130 081G
015 066 45434
Pump # 4 (this one is id'd as the "vw 1V engine?"
NR 0 460 484 027
R 348 BS 4015
068 130 081M
015 161 14514
Pump # 5
NR 0 460 494 072
VE R 66-4
068 130 107 K
011 152  12551
Pump # 6
NR 0 460 494 077
VE R 66-8
068 130 107 AG
011 142   11928
Pump # 7 (Id'd as Nissan/vw Engine CY/JR)
NR 0 460 494 182
R 223 BT 4007
068 130 081 F
015 549  49074
Is there a better place online I could look this information up? My plan is to pick the best one for my car to rebuild and sell off the rest but I wanted a little more information about what I had incase I should make a hybrid/etc... still researching.
I believe that #3 & #4 came off of eco diesels, I think #7 is from a turbo diesel (they have the LDA) and the rest from NA engines. I was told #5 (I think) was from an audi diesel.
Thanks in advance.
-Todd
'81 rabbit 4dr 1.6TD [project]
'98 jetta tdi [daily]
Reply #1March 29, 2010, 09:36:27 am
Re: multiple injection pumps identification help
« Reply #1 on: March 29, 2010, 09:36:27 am »
Pump #1 and #2 are the same
number 6 is off a 1.6 NA found on a rabbit
number 7 is a TD pump of a 1.6 from a late mk2
Reply #2March 30, 2010, 01:36:21 am
famous phil
  • 23
« Reply #2 on: March 30, 2010, 01:36:21 am »
 ;D well at a quick glance they all rotate clockwise  :)  depending on what sort of hybrid your going to build - I'd try use one with a 20mm spindle  :)
Reply #3March 30, 2010, 07:36:24 am
« Reply #3 on: March 30, 2010, 07:36:24 am »
not me, the 20mm shaft is hard to get a proper sprocket for it.
Reply #4March 30, 2010, 09:56:07 am
« Reply #4 on: March 30, 2010, 09:56:07 am »
#1 VW 1.6 Turbo
#2 see above
#3 1.6 NA engine code ME
#4 1.6TD engine code 1V
#5 Audi 4000 engine code CR JK
#6 VW NA engine code CR JK
#7 Nissan 62 Santana 1.6TD engine code CY
OR
1.6 TD engine code MF
Hope this helps. I'm not positive on #1 and #2 because Bosch doesn't have the part > product feature for that pump for some reason.
Reply #5March 31, 2010, 05:54:22 am
fuslit
  • 118
« Reply #5 on: March 31, 2010, 05:54:22 am »
#1 VW 1.6 Turbo
#2 see above
OR
Thanks guys, this is very helpful! In terms of pumps #1 & #2 I'll work on putting up some pics, they look like the turbo diesel pump, but have a secondary fuel solenoid? (from what I can tell) on the side.
I've got sprockets for the majority of the pumps, but I haven't measured the diameter of the shafts on them to see what they are. Currently my plan was to get a seal kit and re-seal the turbo diesel pump (or use the audi pump to get things running.)
Now I need to figure out the easiest/cheapest place for me to get the seal kits.
-Todd
