Author Topic: Rod length of 1.2l tdi ?  (Read 12042 times)
March 23, 2010, 11:45:12 am
ShoulderMan
  • 89
« on: March 23, 2010, 11:45:12 am »
does anyone know the rod length of the 1.2l tdi  or have a spec sheet
 Thanks
-Ron
Reply #1March 23, 2010, 06:53:09 pm
blackdogvan
  • 574
Re: Rod length of 1.2l tdi ?
« Reply #1 on: March 23, 2010, 06:53:09 pm »
Found it here.
http://www.vwdiesel.net/forum/index.php?topic=18691.0
engine configuration & engine displacement
    inline three cylinder (R3/I3) Turbocharged Direct Injection (TDI) turbodiesel; 1,199 cubic centimetres (73.2 cu in), bore x stroke: 79.5 by 80.5 millimetres (3.13 in × 3.17 in), stroke ratio: 0.99:1 - 'square engine', 399.6 cc per cylinder
« Last Edit: March 23, 2010, 06:55:35 pm by blackdogvan »
1991 Vanagon 1.9 mTDI
Reply #2March 24, 2010, 07:54:00 am
ShoulderMan
  • 89
« Reply #2 on: March 24, 2010, 07:54:00 am »
Thank you much,  great find.
 Now,  I need to know the differences between the possibilities of 3 different engines.
there are three sets of 1.2l specs,   each page you listed has a bore and storke different.
page one is 1.2l r3 pd tdi 3l   76.5 x 86.4    1191cc  72.7cid
page two is 1.2l r3 12v tdi     79.5 x 80.5    1199cc  73.2cid
I found bore and stroke at     76.5 x 86.7   1191cm3
edited...
 after a closer look, the 79.5x80.5 is the newer 2008+ versions of the 1.2l
I dont know if that will give me the rod length I am lloking for,   but ill find out soon enough.
thanks
-Ron
« Last Edit: March 24, 2010, 12:16:08 pm by ShoulderMan »
Reply #3March 24, 2010, 12:24:46 pm
ShoulderMan
  • 89
« Reply #3 on: March 24, 2010, 12:24:46 pm »
unfortuantaly i still need the length of the connecting rod,
I have a part number of
045198401
 if this helps.
 thanks
Reply #4March 24, 2010, 05:21:37 pm
ShoulderMan
  • 89
« Reply #4 on: March 24, 2010, 05:21:37 pm »
build a 1.6l tdi, but i need to know the rod length so i can get the proper data to come up with a c/r and storke that will work
   unfortunately the piston and rod used for the 1.2l tdi are shaped differently from the rest of the tdi's, so ill have to make my own
Reply #5March 24, 2010, 08:20:36 pm
blackdogvan
  • 574
« Reply #5 on: March 24, 2010, 08:20:36 pm »
So cost break down:
(lets assume mtdi for both options so the pump cost is similar for both options, either adapt the tdi pump to aneroid pin boost fueling or find a LR pump; I see it as very similar)
1.9 tdi option complete engine cost - $2000-3000ish? (let me know if i'm wrong) done and done.
1.6 idi conversion option - pistons (how much are they actually?), complete head including injectors, injector lines valve cover etc can be found, or sum of the parts, for $750-1000, probably cheaper.
So with no labor costs (because building it would be a labor of love, right?) you'd have to spend over a grand on the pistons to make it not "worth it". The difference could be as high as $2250 if my costing is off.
Who among us can really say we do all this just to save money, I can't. (we'd all be driving hinda civics) Ok i'm sure Andrew will. :) Cool factor is one thing but I don't see this possibility as wasted money, am I wrong?
I say go for it!!
Reply #6March 25, 2010, 11:10:27 am
ShoulderMan
  • 89
« Reply #6 on: March 25, 2010, 11:10:27 am »
I agree with most of it,
 though i already have possession of everything but the pistons,  and the injection pump. right now with all the of inofrmation that I have, the piston in the 1.2l tdi will be 7-thousands of an inch higher than the 1.6l, at tdc.  not much, but enough to hit the vaves if everything else is off as well.  I already have someone who can build the pistons,  which is why i needed to know if the c/r was in the pistons or else where (head gasket).   I want to get the compressio to 17.5:1  that will allow for future changes,  I also live in Arizona, so I dont have to worry about the cold weather starting problems
ive read lots of posts about the idea of a 1.6l tdi, and a lot of people say it will work, but no one has gotten the parts to make it work, nor have they build one that runs... so it cant hurt to try and find the actuall numbers if your gonna try to do it right the first time.
 i figure that if im gonna go all the way with this, I dont want to blow something up while im trying to start it the first time,  becuase like you said, its not cheap.  but it will be cool.  8)
     as far as mpg goes,  no one really knows, maybe it will increase 20% maybe not,  but theres only one way to find out.  everyone says buy the tdi cause you get so much better mpgs, then why not a little more for a 1.6l  or 68mpg for a 1.2l.
   if I can get the pistons made, and everything looks like a go, ill post an official 1.6l tdi thread where ill post all of the progress fron the start.
as for the pistons, even if someone did buy a set, or even one, they would not work because of the different shape they and the rod share to connect togeather.
« Last Edit: March 25, 2010, 11:27:07 am by ShoulderMan »
Reply #7March 26, 2010, 09:45:42 am
« Reply #7 on: March 26, 2010, 09:45:42 am »
If you live at high altitude though that'll effectively lower compression and make starting harder even though it is DI.
Reply #8March 26, 2010, 11:12:55 am
ryanp
  • 269
« Reply #8 on: March 26, 2010, 11:12:55 am »
i can donate a M-TDi pump (11mm, same as Ruben's) to the cause at cost if it means this project will go ahead, i also get jobber discount at the dealer for new parts.
Cheers
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #9March 26, 2010, 11:15:08 am
ShoulderMan
  • 89
« Reply #9 on: March 26, 2010, 11:15:08 am »
the 7 thousands of an inch was measured in the shop vs the spec sheet on the 1.2l tdi piston,
  here is the copy of the pdf  found on page two of idi to di thread
http://www.katech.re.kr/bas/sta/Upload/Board/TBL_ANAL_PART_000396_1.pdf
the reason you cant swap piston and rod is because they are a trapezoidal fit, not normal.  (ill get you that picture as soon as i can)
 I also live in Phoenix, arizona,   no prob with altitude, just heat. (no a/c)
I think i have figured out the reasons as to why no one is able to get any used parts from this engine.
   because of the streach bolts that run all the way through it (head to main bearing)  if you remove the crank shaft, the block deforms out of shape, rendering the block usless,  so there is not too much you can do with the block to strengthen it, only replace it at that point.
Reply #10March 26, 2010, 11:19:32 am
ShoulderMan
  • 89
« Reply #10 on: March 26, 2010, 11:19:32 am »
Ill take you up on that as soon as i get the pistons made, installed and everything looks like a go.    Thank you  8)
Reply #11March 26, 2010, 03:20:40 pm
blackdogvan
  • 574
« Reply #11 on: March 26, 2010, 03:20:40 pm »
Are these 1.2's PD's? Guess that would be the same as me trying to fit a PD piston on mt 1Z rods...
Reply #12April 11, 2012, 10:41:31 pm
JRD
  • 158
« Reply #12 on: April 11, 2012, 10:41:31 pm »
Is it possible to get the 1.2L TDI piston spec sheet?
Do you have find more information about the rod length?
Reply #13April 16, 2012, 07:33:12 am
danster
  • 71
« Reply #13 on: April 16, 2012, 07:33:12 am »
Some 1.9 diesel engine conrod specs.
1Y IDI NA = 150mm long, gud pin 24mm
AAZ IDI TD = 144mm long, gud pin 26mm
1Z TDI = 144mm long, gud pin 26mm
I investigated a longer conrod rod for the petrol engines a while back. Here is some more info on CGTI.
http://www.clubgti.com/forum/showthread.php?t=222440
Reply #14April 16, 2012, 08:04:44 am
« Reply #14 on: April 16, 2012, 08:04:44 am »
I know nothing about it, but what about VR6 rods? Are they even close to what we have? I only ask as I have friend that is building a stroker gas engine out of about 5 VW/Audi engines and he is using VR6 rods to make it all work.
