Author Topic: Why no 1.6l tdi?  (Read 20091 times)
Reply #15July 10, 2010, 09:51:36 am
Re: Why no 1.6l tdi?
« Reply #15 on: July 10, 2010, 09:51:36 am »
you gotta mill 16mm off an aaz deck to get it to where you want it to be. unless you use some sort of longer rods.
the AAZ is 16mm taller than the 1.6 block.
Reply #16July 19, 2010, 02:10:15 pm
oldskool rich
  • 446
« Reply #16 on: July 19, 2010, 02:10:15 pm »
sumone was telling me that a 1.9 is better because its square, ie the stroke is the same as the bore
is that true?
in my mind it makes sence to have a 1.6 crank in a 2.0 block with PD 8v pistons and ALH head u just need to chop the block down and get custom rods
infact im doing just that in my caddy but with stock crank hoping for sum gud power
f6squared I.D.S.T
Reply #17July 19, 2010, 04:04:18 pm
MJF
  • 581
« Reply #17 on: July 19, 2010, 04:04:18 pm »
1,9 is even nowhere near square. Bore 79,5mm and stroke 95,5mm.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #18October 04, 2011, 06:21:15 am
JRD
  • 158
« Reply #18 on: October 04, 2011, 06:21:15 am »
I'm always thinking about a 1.6L TDIm
VW put a 1.6L Common rail TDI engine (called CAYA or CAYB) in the new polo.
Most of the caracteristic of this new engine is similar to 1.9L TDI engine.
I think the 1.6L TDI engine is made from 1.9L engine block with special cranshaft and special conrod.
If it's right, maybe it's possible to do a 1.6L TDim by using the crankshaft and the conrod from a 1.6L CR TDI engine (CAYA or CAYB) in a 1.9L TDI engine (1Z or AFN)!! ;D
Problem: it's hard to find the polo in a scrap yard...  :-\
« Last Edit: October 04, 2011, 01:04:38 pm by JRD »
Reply #19October 04, 2011, 09:24:33 am
« Reply #19 on: October 04, 2011, 09:24:33 am »
you could make a 1.7tdi easily with a 1.6 crank in a tdi block with tdi rods and pistons, you would just need to deck the block down about 9.1mm to get the proper piston height, but this is assuming there is enough webbing in the tdi block.
Reply #20October 04, 2011, 09:25:59 am
« Reply #20 on: October 04, 2011, 09:25:59 am »
how ever due to the nature of how diesel air fuel ratios work, i don't see there being much gain by doing this, maybe slightly better revability due to the short stroke and better rod angles.  but mpg i imagine would remain the same.
Reply #21October 04, 2011, 01:16:14 pm
JRD
  • 158
« Reply #21 on: October 04, 2011, 01:16:14 pm »
The fuel consumption goes down with the engine capacity. ;)
The problem of this engine is caused by the bore who is higher than the stroke, this configuration is normally made for petrol engine to improve RPM...
Reply #22January 12, 2012, 12:45:56 am
JRD
  • 158
« Reply #22 on: January 12, 2012, 12:45:56 am »
After lot of research, I hope I've found a solution to make a 1.6L TDI engine.
- crankcase from a 1.6L TD engine
- cranshaft, connecting-rod from a 1.5L D engine
- piston from a 2.5L V6 TDI engine
- cylinder head from 1.9L TDI engine
The result:
- cubic capacity of 1541cm3 (bore: 78.3mm, stroke: 80mm)
- compression ratio 16,1:1
Modification to do.
- Change the crankcase bore from 76.5 to 78.3mm to accept the 2.5L V6 TDI pistons
- Change the diamètre of the conrod from 22mm to 26mm to accept the piston axle
- Modificate the head to improve compression ratio from 16,1:1 to 19,5:1
Reply #23January 12, 2012, 12:59:23 am
MJF
  • 581
« Reply #23 on: January 12, 2012, 12:59:23 am »
With quick calculating, V6 piston would stick 3mm higher from block than 1,5 piston.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #24January 12, 2012, 01:34:28 am
JRD
  • 158
« Reply #24 on: January 12, 2012, 01:34:28 am »
It's possible.
To ensure it, I need to know exactly the heigt and the axle diameter of the 2.5L V6 TDI piston
Reply #25January 12, 2012, 03:29:55 am
MJF
  • 581
« Reply #25 on: January 12, 2012, 03:29:55 am »
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #26January 12, 2012, 03:50:35 am
JRD
  • 158
« Reply #26 on: January 12, 2012, 03:50:35 am »
Thanks a lot!
Reply #27January 12, 2012, 06:50:12 am
« Reply #27 on: January 12, 2012, 06:50:12 am »
The result:
Modification to do.
sorry, but your not going to bore a 1.5 rod small end out to have enough meat left to have a bushing in the end, and hold a 26mm wrist pin..
time for another solution.
Reply #28January 12, 2012, 12:04:12 pm
JRD
  • 158
« Reply #28 on: January 12, 2012, 12:04:12 pm »
 :( Same player shoot again... ::) ;D
Reply #29January 12, 2012, 11:08:05 pm
JRD
  • 158
« Reply #29 on: January 12, 2012, 11:08:05 pm »
http://www.motorenteile.mahle.com/eLIZA/mahle/query/engine/byParams
Good source for dimensions.
They don't have informations from 1.2L 3 cylinder TDI engine.
I tried the kolbenschmidt site but without success.
Do you know who manufactured this pistons?
