Author Topic: FS: Another 99% Complete 1.6 turbo swap  (Read 6621 times)
March 06, 2010, 02:26:41 pm
« on: March 06, 2010, 02:26:41 pm »
SOLD
This kit comes with just about everything you need. The only piece that I am missing is the air box, however a cone filter will work just fine or you can modify a digi2 air box etc.
What you are buying:
1) T3 turbo - minor shaft play up and down, no in and out. The wastegate looks a little rusty but it is still holding firm. The nuts for the downpipe are kind of crusty. I would recommend replacing them.
2) Downpipe. It's a MK2 style one and is very solid. I don't see any reason why you can't make this one work on a MK1
3) turbo to manifold bolts and intake manifold bolts
4) exhaust manifold
5) complete intake manifold
6) CCV hose
7) Intake hose
8) Boost hose
9) oil feed line
10) oil return line (very hard to find)
11) oil pan
12) oil filter flange stand
13) oil cooler with hoses and metal coolant line. The hoses visually look ok but they are used. The metal coolant line had some spots of heavy rust so I wire wheeled those areas to look for holes. I did not see any. I would recommend painting it, or finding a better replacement unit. I believe that the gas ones are the same. Also, a lot of the NA ones on MK2s are the same so you may already have the proper line.
14) MK2 rear motor mount (apparently they are different) - not pictured
15) Oil pump. I'm assuming that this is a 36mm oil pump found on the later engines. I have not taken it apart to verify that or check it's condition. It was from a 90s TD engine. I also have both bolts which I've read are longer then the ones used on the smaller oil pumps.
Bigger version of above pic
http://img.photobucket.com/albums/v603/burnyourmoney/DSC08258.jpg
Any questions please don't hesitate to ask.
I have and can take detailed pictures of any of the parts.
I'm looking for $550 OBO
I will ship anywhere in the world although it gets spendy if we have to cross an ocean
« Last Edit: March 23, 2010, 07:31:52 pm by burn_your_money »
Reply #1March 08, 2010, 10:28:30 pm
79rabbit4dr
Re: FS: Another 99% Complete 1.6 turbo swap
« Reply #1 on: March 08, 2010, 10:28:30 pm »
If end up picking up this '80 Caddy I'd be really serious about taking this off your hands. I'm checking it out thursday so i'll follow up with you then.
Reply #2March 09, 2010, 04:52:00 am
« Reply #2 on: March 09, 2010, 04:52:00 am »
Ok sounds good.  :)
You shouldn't ruin a wonderful caddy with a turbo though :P
Reply #3March 11, 2010, 04:33:20 pm
goon
  • 35
« Reply #3 on: March 11, 2010, 04:33:20 pm »
is this setup still available or have you parted it out? (saw your other post) have cash would love to get this gathering of parts
Reply #4March 14, 2010, 04:40:39 pm
79rabbit4dr
« Reply #4 on: March 14, 2010, 04:40:39 pm »
Ok sounds good.  :)
it ended up being a piece of crap, he rhino lined the dash, steering wheel, etc. and it tried to run away on me 3 times in my 10 minute test drive... sad sad sad...
i'd turbo it responsible/modestly.
Reply #5March 14, 2010, 07:57:25 pm
« Reply #5 on: March 14, 2010, 07:57:25 pm »
Haha if it ran away on you 3 times without a turbo I can just imagine the fun you would have with one.
Too bad about the truck, if the body is good though dashes and engines are easy to find.
Reply #6March 16, 2010, 07:18:28 am
« Reply #6 on: March 16, 2010, 07:18:28 am »
you got any other turbo swap kits laying around?
Reply #7March 16, 2010, 09:38:30 am
« Reply #7 on: March 16, 2010, 09:38:30 am »
No not really
Reply #8March 17, 2010, 07:36:19 am
« Reply #8 on: March 17, 2010, 07:36:19 am »
damn it, that means steve is gonna keep buggin me....
Reply #9March 17, 2010, 09:50:07 am
« Reply #9 on: March 17, 2010, 09:50:07 am »
Pm sent
