Author Topic: Air water intercooler installed and tested  (Read 11097 times)
February 22, 2010, 12:54:01 pm
idgtd
  • 86
« on: February 22, 2010, 12:54:01 pm »
So, in this thread:
http://www.vwdiesel.net/forum/index.php?topic=18881.0
I've been following my NA turbocharger install and subsequent operation. In the last post, I mentioned I had finished the install of the AWIC, and here it is.
And, I've done some testing on it. Although I'd like to increase my water flow to improve IC efficiency a bit more, the current numbers come out to about 67%.  This screen capture shows the different temperatures of the system during an acceleration run. Red is IC inlet temp, Green is IC outlet temp, and the blue line is ambient air, all in degrees C.
I've also logged the water temperature, and it never climbs more than a few degrees above ambient, so I'm pretty sure that my heat exchanger (modified A/C condenser) is up to the task.
So, now that she's turbocharged, intercooled, and has a 2.25" exhaust, I think it's time to work on the pump for more power......... ;D
Thoughts, comments?
Stephen Phillips
1981 VW Rabbit Diesel (mit turbolader)
1985 VW Scirocco Wolfsburg Ed.
1970 Porsche 911T
1972 MG Midget
1996 Chevy C3500 Dually
1930 Model A Ford
Reply #1February 22, 2010, 01:06:35 pm
truckinwagen
  • 1895
Re: Air water intercooler installed and tested
« Reply #1 on: February 22, 2010, 01:06:35 pm »
very cool!
how are you logging intake temps?
I am thinking about doing the same thing, any idea how much $$ you have into the intercooling system?
also, what are you using as a pump?
« Last Edit: February 22, 2010, 01:09:05 pm by truckinwagen »
83 Opel Kadett Diesel
Reply #2February 22, 2010, 01:21:52 pm
idgtd
  • 86
« Reply #2 on: February 22, 2010, 01:21:52 pm »
I'm logging the temps with a National Instruments data logger and thermocouples. One of the perks of working in automotive research  ;)
As for cost, I got the IC from frozen boost for $150, and that was the bulk of the cost. The silicone couplers cost a good bit to. The rest of it was just fittings and hose. I'd say about $170-200. The pump is a mercedes aux water pump, which isn't really good enough for me but my friend had one lying around. I had a spare A/C condenser lying around, so I modified it for parallel flow and put it in front of the factory rad. and A/C cond.
It was more than I wanted to spend, but then again, it took no time to put it in since the IC piping was so simple.
Stephen Phillips
1970 Porsche 911T
1972 MG Midget
1930 Model A Ford
Reply #3February 22, 2010, 02:49:51 pm
« Reply #3 on: February 22, 2010, 02:49:51 pm »
Awesome, that's pretty much exactly what I want to do to Jezebel!!
What'd you end up doing for a reservoir?
Oh, and do you have an additional fan on the heat exchanger, or are you just relying on the stock one?
Reply #4February 22, 2010, 06:52:51 pm
idgtd
  • 86
« Reply #4 on: February 22, 2010, 06:52:51 pm »
I used a 6" section of 4" pvc. I glued a cap on one end, drilled and tapped ports on it, and left the other end a slip fit. Works great!
No extra fan on my heat exchanger yet, and I don't think I'm going to put one on. The heat soak isn't really an issue thus far, but I'll keep monitoring it.
Stephen Phillips
1970 Porsche 911T
1972 MG Midget
1930 Model A Ford
Reply #5February 22, 2010, 09:43:55 pm
« Reply #5 on: February 22, 2010, 09:43:55 pm »
That's an AWESOME idea... I was planning on trying to find a coolant overflow bottle or something, but the PVC pipe is a nice way to do it - smaller too!  Any idea how much water you've got in your system?
Reply #6February 22, 2010, 09:49:56 pm
truckinwagen
  • 1895
« Reply #6 on: February 22, 2010, 09:49:56 pm »
not only that, but PVC would be the best way to make a reservoir for anything(like my water/meth system)
you could put a threaded end on it, so you could screw it down tight instead of just slipping the end on top.
-Owen
Reply #7February 23, 2010, 12:26:31 am
Syncroincity
  • 727
« Reply #7 on: February 23, 2010, 12:26:31 am »
BRILLIANT!! :D
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #8February 23, 2010, 02:38:38 am
CorsaCruiser
  • 5
    • My stuff
« Reply #8 on: February 23, 2010, 02:38:38 am »
Is an A/C condensor not too restrictive ? (any idea what the waterpressure is,
as these pumps are designed for low pressure, high flow.
Coupling between motor and impeller is magnetic (no direct shaft drive, and no leakage!))
Results look good, have you tried it on a long drive ?
Reply #9February 23, 2010, 08:00:28 am
rodpaslow
  • 670
« Reply #9 on: February 23, 2010, 08:00:28 am »
I'm on the fence between air and water IC.  I'd be interested in what it's like on a long drive as well.
Nice install!
Reply #10February 23, 2010, 08:03:52 am
idgtd
  • 86
« Reply #10 on: February 23, 2010, 08:03:52 am »
Originally the factory type condensor was too restrictive, so I TIG welded a fitting on it to divide the flow into two parallel paths. Now I'm getting about 1.5 GPM through it, but I'd like a little more.
The setup has been on quite a few longer drives, up to about 4 hrs. Works good, no heat soak!
Stephen Phillips
1970 Porsche 911T
1972 MG Midget
1930 Model A Ford
Reply #11April 15, 2011, 06:22:03 am
« Reply #11 on: April 15, 2011, 06:22:03 am »
Hey, bringing this thread back from the dead since I'm close to doing a similar setup... So it's been over a year, still liking the AWIC?
Reply #12April 15, 2011, 09:27:42 am
arb
« Reply #12 on: April 15, 2011, 09:27:42 am »
Nice install!
as water can't cool charge air below 180F, air is more efficient on the highway, but it takes up more space under the hood and is not as efficient at low speeds w/o a fan...
Awesome piece of engineering work !!!  I didn't know there was much automotive research in N.H. :-D  I guess being at the big 3 for so long I missed it.
Reply #13April 15, 2011, 09:46:49 am
blackbird82
  • 151
« Reply #13 on: April 15, 2011, 09:46:49 am »
please explain why water can't cool charge below 180?  John Deere uses AWIC on a lot of applications. and we keep the water at 55 degrees fahrenheit in that system.
I love the whistle......
Reply #14April 17, 2011, 10:05:53 am
« Reply #14 on: April 17, 2011, 10:05:53 am »
Actually if you look at his temp charts you can see he is definitely cooling below 180F!  Looks like his peak post-IC temp was about 32C / 90F.
The place I've most frequently seen that 180F number quoted is when people are talking about using engine coolant for their AWIC setup which is definitely NOT what is happening here...
